Lucas Allrig
  1. Ok. Thank you. I have "solved" it temporally using freeze option in armbian-config. Regards
  2. Hello, First of all, I give thanks to every body that do this fantastic job with armbian. Im newbie on armbian and this world of SOCs. I have an OPI One Plus (and a OPI LITE 2 too..) and I have installed last nightly release Armbian_5.84.190423_Orangepioneplus_Ubuntu_bionic_dev_5.0.7.7z. Seems to works very good. Reboot works fine. But, when I do an upgrade with apt update, apt upgrade, I get 5.84.190505 version. And then, if I do a reboot, board shutdown but when restart (or try do it), there is no hdmi signal nor ethernet connection. The red led is on. If I unplug power supply and plug again, red led shine but I continue with no HDMI output nor ethernet. I this way continously... If I perform a shutdown, it is same situation. Board power off but none when I power on again. Whats wrong? Has anybody this same issue? What I could to do? Thank you in advance. Regards
