Uraroga
Uraroga's Achievements
  1. Thanks for your advice. Unfortunately I have a x96 clone. This model with 4 GB of RAM does not allow other operating systems to start up and does not allow updates of any kind. I can't delete emmc memory.
  2. Hi All Unable to start Armbian on my Smart TV Box, I would like to ask your opinion on the correct boot procedure. I describe my test: I took the file Armbian_5.87_Aml-s905_Ubuntu_bionic_default_5.1.0_desktop_20190521.img.xz I took the Etcher program version 1.5.39. With the program Etcher I flash the "file.Armbian_5.87...img.xz" in my SD (16 GB). in Windows 7 with notepad ++ I modified the uEnv.ini file as follows: test 1 dtb_name=/dtb/meson-gxl-s905w-p281.dtb test 2 dtb_name =/dtb/meson-gxl-s905w-tx3-mini.dtb I left the other information written in the uEnv.ini file unchanged I inserted the micro sd in the Smart Tv Box, I inserted the hdmi cable and I always pressed the reset button inside the AV hole, at the same time I inserted the power cable. The LED on my Smart TV Box has turned red several times and then turned blue. Unfortunately, Android always starts. Key features Amlogic S905W Quad Core ARM Cortex-A53cpu @ up to 2.0GHz with penta Core Mali-450 GPU. (4 GB of RAM and 32 GB disk) with Android version 8.1.0 Thanks for any reply. Greetings
