Apologies to tkaiser, I thought you were part of the administrators.
I did clean a working jessie off of a 32G sandisk sd card (different brand, different size) and loaded the legacy ubuntu trusty as above. I got exactly the same error as before, before and after a reboot. The idea of a fake card starts to wear thin (the stores where they were bought were the most reputable in town). By the way, the working Jessie desktop came from the Armbian download page, one item below the offending one:)
Should this conversation be taken offline? It must be boring for other people till we (i.e. you:) have something actionable.
By the way, I ran all this on two distinct SD cards, unfortunately of the same brand and the same size (Samsung 16G EVO). I will try to liberate a different SD card and repeat the install.
Is there any way in which I can (try to) do the resize2fs by hand and see the feedback if any?
Where is the "/dev/root" if I do not see it in parted or fdisk -l; is it in the ARM equivalent of GRUB? (Actually I am looking for info on what the .raw image looks like and what if anything I can mount and look at. )
Thanks for quick attention.
sudo mount [sudo] password for frits: /dev/mmcblk0p1 on / type ext4 (rw,noatime,nodiratime,commit=600,errors=remount-ro) none on /proc type proc (rw,noexec,nosuid,nodev)
I should have send this too; look at the first line.
This is what I get after rebooting:
df -h /dev/mmcblk0 Filesystem Size Used Avail Use% Mounted on devtmpfs 1.8G 4.0K 1.8G 1% /dev frits@cubox-i:~$ df -h / Filesystem Size Used Avail Use% Mounted on /dev/root 1022M 896M 89M 92% /
/ should be mounted on /mmcblk0p1
Flashed legacy trusty server for Cubox-i onto a 16G SC card.
Installed this succesfully on a Cubox-i4*4 and connected with ssh (no console, after all it is a headless server).
The mount command showed
parted showed one aprtition
1 size 16.0G primary ext4 (as promissed, the partition was extended to use the whole card)
Now comes the disturbing bit
df -h /dev/mmcblk0p1 gives nonsense.
df -h / responds with
/dev/root 1022M 896M used 89M free
Indeed, I tried to load a GUI but it got stuck on a full partition:(
Ideas where this /dev/root came from and why it was not subsumed in the grand mmcblk0p1 partition?
The purpose of all this is a HTPC which can run Youtube and a paid-for channel thru a webbrowser and (my own) movies and music through vlc + a program in Python of my own making. If there is a better way of getting there, by all means tell me.
I was successfull in installing and running the Solid-run Jessie by way of the Ignition installer, but I could not find a 10 foot interface; maybe get my opera glasses out to look at the screen.
