xbean
  1. Thanks for the reply, When I said Raspberry Pi I should have specified that it was the Raspberry Pi 3 B+ not the original RPi. Are you saying that there is no support whatsoever for CAN bus on Rockchip RK3399 based SoCs? I have both a NanoPi M4 and a Rock Pi 4 and was going to try and set up the CAN module on either of them. Do these boards function the same was as the RPi 3B+? As in, is it the same method to activate the overlays by adding the lines below to the /boot/config.txt file? dtparam=i2c_arm=on dtparam=spi=on enable_uart=1 dtoverlay=mcp2515-can0,oscillator=16000000,interrupt=25 dtoverlay=spi-bcm2835-overlay Thanks
  2. I am currently trying to set up the PICAN GPS+ACC Rev B on my NanoPi M4 in order to receive CAN connections. I have previously set this up on a Raspberry Pi with no issues, but because the NanoPi does not have /boot/config.txt and /boot/cmdline.txt I am at a loss at how to set up the module. Any information as to how I can go about using the module on the NanoPi would be much appreciated. The guide I used to set up the module on the Raspberry Pi is here http://skpang.co.uk/catalog/images/raspberrypi/pican/PICANGPSACC_V1.pdf Thanks
