Here is the serial port output for boinic
U-Boot SPL 2019.04-armbian (Jul 06 2019 - 15:13:59 +0200)
DRAM: 2048 MiB
Trying to boot from MMC1
NOTICE: BL3-1: Running on A64/H64 (1689) in SRAM A2 (@0x44000)
NOTICE: Configuring SPC Controller
NOTICE: BL3-1: v1.0(debug):c9f55c0
NOTICE: BL3-1: Built : 14:30:11, Jul 6 2019
NOTICE: DT: sun50i-a64-bananapi-m64
INFO: Configuring AXP PMIC
INFO: PMIC: DRAM voltage: 1.50V
INFO: PMIC: setup successful
NOTICE: SCPI: dummy stub handler, implementation level: 000000
INFO: BL3-1: Initializing runtime services
INFO: BL3-1: Preparing for EL3 exit to normal world
INFO: BL3-1: Next image address: 0x4a000000, SPSR: 0x3c9
U-Boot 2019.04-armbian (Jul 06 2019 - 15:13:59 +0200) Allwinner Technology
CPU: Allwinner A64 (SUN50I)
Model: BananaPi-M64
DRAM: 2 GiB
MMC: Device 'mmc@1c11000': seq 1 is in use by 'mmc@1c10000'
mmc@1c0f000: 0, mmc@1c10000: 2, mmc@1c11000: 1
Loading Environment from EXT4... ** File not found /boot/boot.env **
** Unable to read "/boot/boot.env" from mmc0:1 **
In: serial
Out: serial
Err: serial
Allwinner mUSB OTG (Peripheral)
Net: phy interface7
eth0: ethernet@1c30000
Warning: usb_ether using MAC address from ROM
, eth1: usb_ether
230454 bytes read in 13 ms (16.9 MiB/s)
starting USB...
USB0: USB EHCI 1.00
USB1: USB OHCI 1.0
USB2: USB EHCI 1.00
USB3: USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 1 for devices... 1 USB Device(s) found
scanning bus 2 for devices... 2 USB Device(s) found
scanning bus 3 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot/boot.scr
3042 bytes read in 1 ms (2.9 MiB/s)
## Executing script at 4fc00000
U-boot loaded from SD
Boot script loaded from mmc
153 bytes read in 1 ms (149.4 KiB/s)
33861 bytes read in 5 ms (6.5 MiB/s)
3795 bytes read in 3 ms (1.2 MiB/s)
Applying kernel provided DT fixup script (sun50i-a64-fixup.scr)
## Executing script at 44000000
8741673 bytes read in 428 ms (19.5 MiB/s)
14311432 bytes read in 698 ms (19.6 MiB/s)
## Loading init Ramdisk from Legacy Image at 4fe00000 ...
Image Name: uInitrd
Image Type: AArch64 Linux RAMDisk Image (gzip compressed)
Data Size: 8741609 Bytes = 8.3 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 4fa00000
Booting using the fdt blob at 0x4fa00000
Loading Ramdisk to 497a9000, end 49fff2e9 ... OK
Loading Device Tree to 0000000049738000, end 00000000497a8fff ... OK
Starting kernel ...
[ 11.258136] Unable to handle kernel paging request at virtual address 000000007323d5f2
[ 11.266065] Mem abort info:
[ 11.268856] ESR = 0x96000004
[ 11.271908] Exception class = DABT (current EL), IL = 32 bits
[ 11.277820] SET = 0, FnV = 0
[ 11.280869] EA = 0, S1PTW = 0
[ 11.284005] Data abort info:
[ 11.286882] ISV = 0, ISS = 0x00000004
[ 11.290712] CM = 0, WnR = 0
[ 11.293680] user pgtable: 4k pages, 48-bit VAs, pgdp = 00000000e976007a
[ 11.300287] [000000007323d5f2] pgd=0000000000000000
[ 11.305161] Internal error: Oops: 96000004 [#1] SMP
[ 11.310034] Modules linked in: zstd zram brcmfmac brcmutil snd_soc_hdmi_codec snd_soc_spdif_tx snd_soc_simple_card snd_soc_simple_card_utils snd_soc_core cfg80211 snd_pcm_dmaengine lima snd_pcm snd_timer gpu_sched snd ttm axp20x_battery axp20x_ac_power soundcore dw_hdmi_cec dw_hdmi_i2s_audio axp20x_adc sun4i_gpadc_iio industrialio cpufreq_dt thermal_sys sch_fq_codel pinctrl_axp209 realtek
[ 11.344469] Process swapper/2 (pid: 0, stack limit = 0x000000001e795c4b)
[ 11.351177] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 4.19.57-sunxi64 #5.90
[ 11.358130] Hardware name: BananaPi-M64 (DT)
[ 11.362396] pstate: 60000085 (nZCv daIf -PAN -UAO)
[ 11.367192] pc : rcu_is_cpu_rrupt_from_idle+0x0/0x38
[ 11.372154] lr : rcu_check_callbacks+0x60/0x780
[ 11.376678] sp : ffff000008013d50
[ 11.379989] x29: ffff000008013d50 x28: ffff80007bfa3280
[ 11.385296] x27: ffff80007bfa2d40 x26: 0000000000000000
[ 11.390604] x25: 0000000000000080 x24: 000000029eabeb09
[ 11.395912] x23: ffff80007bfa2da0 x22: 0000000000000000
[ 11.401219] x21: ffff00000919bdf0 x20: 0000000000000000
[ 11.406526] x19: ffff000008d92000 x18: 0000000000000000
[ 11.411834] x17: 0000000000000000 x16: 0000000000000000
[ 11.417141] x15: 0000000000000400 x14: 0000000000000400
[ 11.422449] x13: 0000000000000001 x12: 0000000000000000
[ 11.427756] x11: ffff000008d6dd6e x10: 0000000000000040
[ 11.433064] x9 : ffff000008d91f48 x8 : ffff800079400248
[ 11.438371] x7 : ffff800079400290 x6 : 000000001ed85bb5
[ 11.443679] x5 : 000080007323d000 x4 : ffff000008d92e40
[ 11.448986] x3 : 000080007323d000 x2 : ffff000008d92aa8
[ 11.454294] x1 : 00000000000005f2 x0 : ffff000008d92e40
[ 11.459602] Call trace:
[ 11.462048] rcu_is_cpu_rrupt_from_idle+0x0/0x38
[ 11.466663] update_process_times+0x2c/0x58
[ 11.470846] tick_sched_handle.isra.5+0x30/0x48
[ 11.475372] tick_sched_timer+0x48/0x98
[ 11.479204] __hrtimer_run_queues+0xe4/0x1f8
[ 11.483471] hrtimer_interrupt+0xf4/0x2b0
[ 11.487481] arch_timer_handler_phys+0x28/0x40
[ 11.491921] handle_percpu_devid_irq+0x80/0x138
[ 11.496450] generic_handle_irq+0x24/0x38
[ 11.500456] __handle_domain_irq+0x5c/0xb0
[ 11.504550] gic_handle_irq+0x58/0xa8
[ 11.508210] el1_irq+0xb0/0x140
[ 11.511349] arch_cpu_idle+0x10/0x18
[ 11.514923] do_idle+0x1d4/0x298
[ 11.518149] cpu_startup_entry+0x20/0x28
[ 11.522071] secondary_start_kernel+0x18c/0x1c8
[ 11.526600] Code: b00063e0 91190000 91100000 17fffff7 (d0006261)
[ 11.532689] ---[ end trace 0400e26ad3ded69d ]---
[ 11.537302] Kernel panic - not syncing: Fatal exception in interrupt
[ 11.543651] SMP: stopping secondary CPUs
[ 11.547571] Kernel Offset: disabled
[ 11.551057] CPU features: 0x0,24802004
[ 11.554801] Memory Limit: none
[ 11.557856] Rebooting in 10 seconds..
