Ruediger
  1. Hello! Whilst I, so far, only used a BPi M5 as a multirole-server (Mumble, Apache, Minecraft), I'd use a 16GB BPi M7 as an OpenSimulator node. And, depending upon the availability under Armbian of an LLM able to use the NPU, I'd use that to have a locally hosted Chat-Help-Bot in that OpenSimulator node. Admittedly, I have no clue of how to do that - but there's other LLM's that might have the knowledge to guide me through that process. Or some human able and willing to help. The aim would be to have a selfcontained OpenSimulator Sim able to serve as both a login point to the Hypergrid/Metaverse as well as having an integrated, interactive helpcenter for newbies. And, too, to have a general point of contact that's staffed 24/7. Well, and I'd use the fact I don't see any cases so far for the M7 to design one that's FDM printable. With kind regards Rüdiger
  2. Hello! Question to the OP: Is this: https://www.amazon.de/Android-Quad-Core-Cortex-A53-Enternet-Bluetooth/dp/B0BYCK85LB the type of settopbox you're using? If so, where did you get the image you're using? I'm using an Odroid C2 for my mediaserver, but with passive cooling it runs damnably hot and with active cooling it's not fit to run in my living room. Before the C2, I had an Mecool M8S Pro W, for several years, but the S905W chipset is no longer supported and I need a series 6 kernel to run it, so I was looking what the Settop boxes offer these days and found your thread. It reads as if the basic functionality was reached almost out of the box, what is what I am looking for.
  3. Hello! I watch this thread since a year, so far no update and the issue still exists in Bookworm for a Odroid-C2 booting into the current bookworm image on MicroSD ( as of writing this, that's Armbian 23.8 Bookworm ). Is there any chance of this being solved? I tried with a Kingston (32GB), an Intenso (8GB), a Sandisk (16GB) and a Toshiba (64GB) MicoSD card. If this cannot be solved...: Any recommends where to get a Toshiba or Sandisk eMMC module? I wasn't very lucky with the Odroid ones for my N2 and N2+, but didn't find any other compatible eMMC modules so far. And I'm not planning on soldering some BGA chips out and in. X(
