Vicky
Vicky's Achievements
  1. Thanks a lot ...!!! to both lgor and guidol. It is working with this image : https://dl.armbian.com/lime2/archive/Armbian_5.90_Lime2_Ubuntu_bionic_next_4.19.57.7z.
  2. Thanks for the reply.... I have both T2-SOM-e8Gs16M-IND and A20-SOM-EVB. I am using A20-SOM-EVB as a breakout board.
  3. Thank you for the rply, I am new to Armbian so, could you pl suggest stable Armbian build for T2-SOM-e8Gs16M. and How to disable IPV6.
  4. Hi, I could not able to download and install any packages, following is the eg. i was trying to install dkms package sudo apt install dkms Reading package lists... Done Building dependency tree Reading state information... Done E: Unable to locate package dkms in addtion apt update is running partial , throwing errors as below sudo apt update Get:2 http://ports.ubuntu.com bionic InRelease [242 kB] Hit:3 http://repository.olimex.com bionic InRelease Get:2 http://ports.ubuntu.com bionic InRelease [242 kB] Err:1 https://apt.armbian.com bionic InRelease Could not wait for server fd - select (11: Resource temporarily unavailable) [IP: 2001:bb8:4008:20:5054:ff:fea8:96fc 443] Get:2 http://ports.ubuntu.com bionic InRelease [242 kB] Get:2 http://ports.ubuntu.com bionic InRelease [242 kB] Err:2 http://ports.ubuntu.com bionic InRelease Connection failed [IP: 91.189.88.150 80] Get:4 http://ports.ubuntu.com bionic-security InRelease [88.7 kB] Get:4 http://ports.ubuntu.com bionic-security InRelease [88.7 kB] Get:4 http://ports.ubuntu.com bionic-security InRelease [88.7 kB] Get:4 http://ports.ubuntu.com bionic-security InRelease [88.7 kB] Get:4 http://ports.ubuntu.com bionic-security InRelease [88.7 kB] Get:5 http://ports.ubuntu.com bionic-updates InRelease [88.7 kB] Get:5 http://ports.ubuntu.com bionic-updates InRelease [88.7 kB] Get:5 http://ports.ubuntu.com bionic-updates InRelease [88.7 kB] Get:5 http://ports.ubuntu.com bionic-updates InRelease [88.7 kB] Get:5 http://ports.ubuntu.com bionic-updates InRelease [88.7 kB] Get:5 http://ports.ubuntu.com bionic-updates InRelease [88.7 kB] Get:5 http://ports.ubuntu.com bionic-updates InRelease [88.7 kB] Hit:6 http://ports.ubuntu.com bionic-backports InRelease Get:7 http://ports.ubuntu.com bionic-security/main armhf Packages [304 kB] Get:7 http://ports.ubuntu.com bionic-security/main armhf Packages [304 kB] Ign:7 http://ports.ubuntu.com bionic-security/main armhf Packages Get:8 http://ports.ubuntu.com bionic-security/restricted armhf Packages [3968 B] Get:9 http://ports.ubuntu.com bionic-security/universe armhf Packages [467 kB] Ign:9 http://ports.ubuntu.com bionic-security/universe armhf Packages Get:10 http://ports.ubuntu.com bionic-security/multiverse armhf Packages [1924 B] Get:11 http://ports.ubuntu.com bionic-updates/main armhf Packages [518 kB] Get:11 http://ports.ubuntu.com bionic-updates/main armhf Packages [518 kB] Ign:11 http://ports.ubuntu.com bionic-updates/main armhf Packages Get:12 http://ports.ubuntu.com bionic-updates/restricted armhf Packages [6504 B] Ign:13 http://ports.ubuntu.com bionic-updates/universe armhf Packages Get:14 http://ports.ubuntu.com bionic-updates/multiverse armhf Packages [3964 B] Ign:7 http://ports.ubuntu.com bionic-security/main armhf Packages Get:9 http://ports.ubuntu.com bionic-security/universe armhf Packages [467 kB] Ign:9 http://ports.ubuntu.com bionic-security/universe armhf Packages Get:11 http://ports.ubuntu.com bionic-updates/main armhf Packages [518 kB] Err:11 http://ports.ubuntu.com bionic-updates/main armhf Packages File has unexpected size (518664 != 518472). Mirror sync in progress? [IP: 91.189.88.150 80] Hashes of expected file: - Filesize:518472 [weak] - SHA256:4a0cf88f09c6fb9037cbe727e0f855b8858f7a7d6479c04730662aab472bdb92 - SHA1:7521c8429b133d76fa0836bcd9836f30fcc802ca [weak] - MD5Sum:c1dab514e64a1dd166f701d98a5eb98d [weak] Release file created at: Tue, 06 Aug 2019 06:34:50 +0000 Get:13 http://ports.ubuntu.com bionic-updates/universe armhf Packages [828 kB] Err:13 http://ports.ubuntu.com bionic-updates/universe armhf Packages Get:7 http://ports.ubuntu.com bionic-security/main armhf Packages [389 kB] Ign:7 http://ports.ubuntu.com bionic-security/main armhf Packages Ign:9 http://ports.ubuntu.com bionic-security/universe armhf Packages Err:7 http://ports.ubuntu.com bionic-security/main armhf Packages Could not connect to ports.ubuntu.com:80 (91.189.88.150), connection timed out Could not connect to ports.ubuntu.com:80 (2001:67c:1360:8001::22), connection timed out [IP: 91.189.88.150 80] Err:9 http://ports.ubuntu.com bionic-security/universe armhf Packages Connection failed [IP: 91.189.88.150 80] Fetched 18.3 kB in 24min 30s (12 B/s) Reading package lists... Done W: Failed to fetch http://ports.ubuntu.com/dists/bionic/InRelease Connection failed [IP: 91.189.88.150 80] W: Failed to fetch http://apt.armbian.com/dists/bionic/InRelease Could not wait for server fd - select (11: Resource temporarily unavailable) [IP: 2001:bb8:4008:20:5054:ff:fea8:96fc 443] W: Failed to fetch http://ports.ubuntu.com/dists/bionic-security/main/binary-armhf/Packages Could not connect to ports.ubuntu.com:80 (91.189.88.150), connection timed out Could not connect to ports.ubuntu.com:80 (2001:67c:1360:8001::22), connection timed out [IP: 91.189.88.150 80] W: Failed to fetch http://ports.ubuntu.com/dists/bionic-security/universe/binary-armhf/Packages Connection failed [IP: 91.189.88.150 80] E: Failed to fetch http://ports.ubuntu.com/dists/bionic-updates/main/binary-armhf/Packages.xz File has unexpected size (518664 != 518472). Mirror sync in progress? [IP: 91.189.88.150 80] Hashes of expected file: - Filesize:518472 [weak] - SHA256:4a0cf88f09c6fb9037cbe727e0f855b8858f7a7d6479c04730662aab472bdb92 - SHA1:7521c8429b133d76fa0836bcd9836f30fcc802ca [weak] - MD5Sum:c1dab514e64a1dd166f701d98a5eb98d [weak] Release file created at: Tue, 06 Aug 2019 06:34:50 +0000 E: Failed to fetch http://ports.ubuntu.com/dists/bionic-updates/universe/binary-armhf/Packages.xz W: Some index files failed to download. They have been ignored, or old ones used instead. W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/armbian.list:1 and /etc/apt/sources.list.d/armbian.list:2 W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/armbian.list:1 and /etc/apt/sources.list.d/armbian.list:2 W: Target CNF (main/cnf/Commands-armhf) is configured multiple times in /etc/apt/sources.list.d/armbian.list:1 and /etc/apt/sources.list.d/armbian.list:2 W: Target CNF (main/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list.d/armbian.list:1 and /etc/apt/sources.list.d/armbian.list:2 W: Target Packages (bionic-utils/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/armbian.list:1 and /etc/apt/sources.list.d/armbian.list:2 W: Target Packages (bionic-utils/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/armbian.list:1 and /etc/apt/sources.list.d/armbian.list:2 W: Target CNF (bionic-utils/cnf/Commands-armhf) is configured multiple times in /etc/apt/sources.list.d/armbian.list:1 and /etc/apt/sources.list.d/armbian.list:2 W: Target CNF (bionic-utils/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list.d/armbian.list:1 and /etc/apt/sources.list.d/armbian.list:2 W: Target Packages (bionic-desktop/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/armbian.list:1 and /etc/apt/sources.list.d/armbian.list:2 W: Target Packages (bionic-desktop/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/armbian.list:1 and /etc/apt/sources.list.d/armbian.list:2 W: Target CNF (bionic-desktop/cnf/Commands-armhf) is configured multiple times in /etc/apt/sources.list.d/armbian.list:1 and /etc/apt/sources.list.d/armbian.list:2 W: Target CNF (bionic-desktop/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list.d/armbian.list:1 and /etc/apt/sources.list.d/armbian.list:2
