Hello everyone, I know this is a well known problem of the OPi Zero, but in regarding to "solutions":
h3consumption works only with the legacy kernel because of the use of Fex
Is there a way to tweak the things h3consumption did in the mainline version?
In the mainline version from armbian-config it is possible to disable USB, in /etc/default/cpufrequtils it is also possible to set the maximum frequency and wifi can be disabled.
Does anyone know any option for disabling the GPU, limit the DRAM clockspeed and the maximum active cores? Is the only possibility
to recompile the kernel, at the moment?
Unfortunately the main tutorial about h3consumption is no longer available
