Tomte
8 -
I went back to: Armbian_21.02.3_Cubietruck_buster_current_5.10.21.img.xz That one is booting. Did "Freeze" Thanks!
Wow, that was quick. Ok, how long would I have to wait? Can I use an old release? which one? I don't have a running build environment. Regards, Tomte
So I reflashed the SDCard with a current buster, but I can not boot. It is ending up in a boot loop. Please, what can I do? U-Boot SPL 2021.04-armbian (May 06 2021 - 17:01:36 +0000) DRAM: 2048 MiB CPU: 912000000Hz, AXI/AHB/APB: 3/2/2 Trying to boot from MMC1 U-Boot 2021.04-armbian (May 06 2021 - 17:01:36 +0000) Allwinner Technology CPU: Allwinner A20 (SUN7I) Model: Cubietech Cubietruck I2C: ready DRAM: 2 GiB MMC: mmc@1c0f000: 0, mmc@1c12000: 1 Loading Environment from FAT... Card did not respond to voltage select! : -110 HDMI connected: Setting up a 1600x1200 dvi console (overscan 0x0) In: serial Out: vga Err: vga Allwinner mUSB OTG (Peripheral) Net: eth0: ethernet@1c50000, eth1: usb_ether 230454 bytes read in 22 ms (10 MiB/s) starting USB... Bus usb@1c14000: USB EHCI 1.00 Bus usb@1c14400: USB OHCI 1.0 Bus usb@1c1c000: USB EHCI 1.00 Bus usb@1c1c400: USB OHCI 1.0 scanning bus usb@1c14000 for devices... 1 USB Device(s) found scanning bus usb@1c14400 for devices... 2 USB Device(s) found scanning bus usb@1c1c000 for devices... 1 USB Device(s) found scanning bus usb@1c1c400 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3967 bytes read in 3 ms (1.3 MiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 154 bytes read in 3 ms (49.8 KiB/s) 9932361 bytes read in 848 ms (11.2 MiB/s) 7973464 bytes read in 681 ms (11.2 MiB/s) Found mainline kernel configuration 43983 bytes read in 8 ms (5.2 MiB/s) 5532 bytes read in 9 ms (599.6 KiB/s) Applying kernel provided DT fixup script (sun7i-a20-fixup.scr) ## Executing script at 45000000 ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 9932297 Bytes = 9.5 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 data abort pc : [<bef89cec>] lr : [<00000011>] reloc pc : [<4a013cec>] lr : [<8b08a011>] sp : baf4aa18 ip : 00000000 fp : befdd678 r10: 00000020 r9 : baf55ec0 r8 : befea28c r7 : 6c616972 r6 : 00000010 r5 : 2756f9ea r4 : baf59070 r3 : baf59078 r2 : baf59068 r1 : baf9f920 r0 : 00000019 Flags: nzCv IRQs off FIQs off Mode SVC_32 (T) Code: d005 f027 0501 441d (686d) 07ed Resetting CPU ... resetting ... U-Boot SPL 2021.04-armbian (May 06 2021 - 17:01:36 +0000) DRAM: 2048 MiB CPU: 912000000Hz, AXI/AHB/APB: 3/2/2 Trying to boot from MMC1
Hello, yes, it is a A20. thanks for your answer, here you go: => boot switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3708 bytes read in 21 ms (171.9 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 202 bytes read in 17 ms (10.7 KiB/s) ** File not found /boot/uInitrd ** 7967848 bytes read in 692 ms (11 MiB/s) Found mainline kernel configuration 43983 bytes read in 41 ms (1 MiB/s) 5532 bytes read in 123 ms (43 KiB/s) Applying kernel provided DT fixup script (sun7i-a20-fixup.scr) ## Executing script at 44000000 Wrong Ramdisk Image Format Ramdisk image is corrupt or invalid SCRIPT FAILED: continuing... Card did not respond to voltage select! scanning bus for devices... Device 0: (0:0) Vendor: ATA Prod.: SanDisk SDSSDP12 Rev: 2.0. Type: Hard Disk Capacity: 122104.3 MB = 119.2 GB (250069680 x 512) Found 1 device(s). Device 0: (0:0) Vendor: ATA Prod.: SanDisk SDSSDP12 Rev: 2.0. Type: Hard Disk Capacity: 122104.3 MB = 119.2 GB (250069680 x 512) ... is now current device Scanning scsi 0:1... Device 0: device type unknown ... is now current device ** Bad device usb 0 ** ** Bad device usb 0 ** Speed: 1000, full duplex BOOTP broadcast 1 DHCP client bound to address 192.168.180.97 (15 ms) Using ethernet@01c50000 device TFTP from server 192.168.180.1; our IP address is 192.168.180.97 Filename 'boot.scr.uimg'. Load address: 0x43100000 Loading: *
Hello, I was running Armbian on my cubietruck, I believe Bionic Ubuntu. I wanted to upgrade to latest kernel, so I did a - apt-get update - apt-get upgrade - ambian-config and selected the lastest kernel And that was it. When rebooting, I end up with a try to contact a tftp server. The cubietruck has an SDCard and an SSD. Is there an easy fix or do I need to reinstall it completely, please? If I need to reinstall, do I have to backup all data, or is existing data preserved? (Traccar installation) Regards, Tomte
My problem was, that lsb_release did not give to useful information. I reinstalled lsb-release, now it it working. I upgrade to v. 12 with the manual installation from here: https://github.com/nodesource/distributions#debmanual
Hello, has anyone found a way to get a relatively new nodejs running on Armbian Bionic? I can not find one. I always end up with a not supported plattform. I am using a banana Pi M2 plus. I currently have a very old one running, (8.x) and I can not remember how I did that. Thank you for your support!
Hello, I try to compile node.js on my BananaPI M2+. Everly now an then I get segmentation faults, internal compiler errors. The strange thing is, then when I restart, it runs further, just to crash at some later point. I already reduced cpu speed to 1GHz, and I am only compiling using one core, now. CPU temp is aroung 60°C now. Still every now and then, it happens. Checking with top, memory seems to be doing fine, too. What else cound I do? Regards, Tomte. PS: I am using a new SanDisk Ultra 16GB SD card. PPS: According to Rpi, I am running out of memory, how can I prevent this, please?
