Previously worked, but not now.
I am stuck in the login line and cannot login with the keyboard from the putty screen.
I cant login with keyboard on USB2.
Also HDMI not working. HDMI previously worked too.
I am newbie. Thanks in advance.
I cant remember which version loaded on the eMMC.
U-Boot SPL 2019.04-armbian (Jul 06 2019 - 20:55:41 +0200)
DRAM: 2048 MiB
Trying to boot from MMC2
NOTICE: BL31: v2.1(debug):bb2d778-dirty
NOTICE: BL31: Built : 20:55:33, Jul 6 2019
NOTICE: BL31: Detected Allwinner H6 SoC (1728)
NOTICE: BL31: Found U-Boot DTB at 0xc079e78, model: OrangePi 3
INFO: ARM GICv2 driver initialized
NOTICE: PMIC: Probing AXP805
NOTICE: PMIC: AXP805 detected
INFO: BL31: Platform setup done
INFO: BL31: Initializing runtime services
INFO: BL31: cortex_a53: CPU workaround for 855873 was applied
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x4a000000
INFO: SPSR = 0x3c9
U-Boot 2019.04-armbian (Jul 06 2019 - 20:55:41 +0200) Allwinner Technology
CPU: Allwinner H6 (SUN50I)
Model: OrangePi 3
DRAM: 2 GiB
MMC: mmc@4020000: 0, mmc@4022000: 1
Loading Environment from EXT4... Card did not respond to voltage select!
In: serial@5000000
Out: serial@5000000
Err: serial@5000000
Net: No ethernet found.
starting USB...
No controllers found
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1(part 0) is current device
Scanning mmc 1:1...
Found U-Boot script /boot/boot.scr
3042 bytes read in 1 ms (2.9 MiB/s)
## Executing script at 4fc00000
U-boot loaded from SD
Boot script loaded from mmc
165 bytes read in 0 ms
29583 bytes read in 5 ms (5.6 MiB/s)
4161 bytes read in 3 ms (1.3 MiB/s)
Applying kernel provided DT fixup script (sun50i-h6-fixup.scr)
## Executing script at 44000000
9135838 bytes read in 923 ms (9.4 MiB/s)
15147016 bytes read in 1530 ms (9.4 MiB/s)
## Loading init Ramdisk from Legacy Image at 4fe00000 ...
Image Name: uInitrd
Image Type: AArch64 Linux RAMDisk Image (gzip compressed)
Data Size: 9135774 Bytes = 8.7 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 4fa00000
Booting using the fdt blob at 0x4fa00000
Loading Ramdisk to 49749000, end 49fff69e ... OK
Loading Device Tree to 00000000496d9000, end 0000000049748fff ... OK
Starting kernel ...
Ubuntu 18.04.3 LTS orangepi3 ttyS0
orangepi3 login:
And
This one is Armbian_19.11.4_Orangepi3_bionic_current_5.4.6_desktop with SDCard boot. (2019-12-23)
U-Boot SPL 2019.10-armbian (Dec 23 2019 - 09:47:42 +0100)
DRAM: 2048 MiB
Trying to boot from MMC1
NOTICE: BL31: v2.2(debug):aeb3d83-dirty
NOTICE: BL31: Built : 09:47:34, Dec 23 2019
NOTICE: BL31: Found U-Boot DTB at 0xc07f048, model: OrangePi 3
INFO: PMIC: Probing AXP805 on I2C
INFO: PMIC: aldo1 voltage: 3.300V
INFO: PMIC: aldo2 voltage: 3.300V
INFO: PMIC: aldo3 voltage: 3.300V
INFO: PMIC: bldo1 voltage: 1.800V
INFO: PMIC: bldo2 voltage: 1.800V
INFO: PMIC: bldo3 voltage: 1.800V
INFO: PMIC: cldo1 voltage: 3.300V
INFO: PMIC: dcdcd voltage: 0.960V
INFO: PMIC: dcdce voltage: 1.200V
INFO: SPSR = 0x3c9
U-Boot 2019.10-armbian (Dec 23 2019 - 09:47:42 +0100) Allwinner Technology
Model: OrangePi 3
DRAM: 2 GiB
Loading Environment from EXT4... ** File not found /boot/boot.env **
** Unable to read "/boot/boot.env" from mmc0:1 **
In: serial@5000000
Out: serial@5000000
Err: serial@5000000
mmc0 is current device
Scanning mmc 0:1...
3033 bytes read in 12 ms (246.1 KiB/s)
165 bytes read in 7 ms (22.5 KiB/s)
31388 bytes read in 39 ms (785.2 KiB/s)
4161 bytes read in 40 ms (101.6 KiB/s)
9549521 bytes read in 1010 ms (9 MiB/s)
15685640 bytes read in 1650 ms (9.1 MiB/s)
Image Name: uInitrd
Data Size: 9549457 Bytes = 9.1 MiB
Loading Ramdisk to 496e4000, end 49fff691 ... OK
Loading Device Tree to 0000000049673000, end 00000000496e3fff ... OK
Starting kernel ...
[ 17.213687] dwmac-sun8i 5020000.ethernet eth0: no phy at addr -1
[ 17.222692] dwmac-sun8i 5020000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
[ 17.386257] dwmac-sun8i 5020000.ethernet eth0: no phy at addr -1
[ 17.395289] dwmac-sun8i 5020000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
[ 17.428555] dwmac-sun8i 5020000.ethernet eth0: no phy at addr -1
[ 17.437574] dwmac-sun8i 5020000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
[ 17.466272] dwmac-sun8i 5020000.ethernet eth0: no phy at addr -1
[ 17.475285] dwmac-sun8i 5020000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
[ 17.504444] dwmac-sun8i 5020000.ethernet eth0: no phy at addr -1
[ 17.513515] dwmac-sun8i 5020000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19)
Armbian 19.11.4 Bionic ttyS0
orangepi3 login:
