Hi All, thanks for this great project, much appreciated!
Could someone give me an educated guess whether there is a risk of damaging my board when the blue LED is flashing much faster (at least twice, probably more) than usual? I suspect something is changing the frequency or voltage and I'm not sure how much time I can take in this state to try to analyze the problem further. For now I unplug the power when it happens.
I'm trying to netboot my Rock Pi 4B v1.4 with the current or dev branches of buster minimal nfsboot, with no local storage at all (just the SPI flash for u-boot). The legacy 4.4 hangs at very early boot (couldn't get clock / Failed to get pclk) so I gave up on that, but it does work fine when running from an SD card.
With the vanilla rootfs.tgz for 5.4.y/5.5.y extracted on the NFS server the boot process waits for 90 seconds trying to mount a device by UUID on /boot. Then I get the maintenance prompt where I can login with the default root password and all is relatively fine and working.
I commented out the offending line in /etc/fstab. Now when I reboot, the board seems to hang somewhere in the boot process (I see the mount of root on the NFS server logs, the last messages on the monitor are "Started Serial Getty on ttyS2." and "Started Getty on tty1."; the last messages on the serial console are "[ 55.471075] systemd[1]: Reached target Swap." and "[ 55.471789] random: systemd: uninitialized urandom read (16 bytes read)") and then the frequency of the blue LED slowly (over the course of 10-15 seconds or so?) increases to at least twice as fast. Any ideas what causes this and what it means?
Thanks,
Arjan
