Hello,
I have some stability issues also with the Vanilla Jessie Armbian.
I have a Lime 2 (rev C) board which works perfectly fine, I recently bought a new one, and this board randomly hangs. I have tested many times with the same configuration that the working board (same SD card, power source).
It seems to happen more frequently when the load on the board increases.
So I tried changing the "governor" value in /etc/default/cpufrequtils to performance. Same issues.
I have built a new image, lowering the DRAM clock to 384. The board still hangs randomly.
As it is the first time I build a new image, I want to make sure that the modification on the DRAM clock speed is in the image.
Is it possible to check on a running board the DRAM clock frequency? If yes, how?
