davpal
  1. Hi, Even though the old sources packages also work fine for me, now i can compile rtl8812au driver with the parts that use floating point. Is now the kernel compiled without mgeneral-regs-only? Thank you,
  2. Hi, Recenlly i had to change the emmc max-frequency in dts, meson-g12a-u200.dts, to make work an A95x f2 (s905x2) with armbian installed on the emmc. With this configuration the secuencial read speed on the emmc is about 95.4MB/s. Also i have an beelink gt1 mini working 24x7 for several month without major issues, but the emmc performance is worst, around 43.1MB/s. I modified meson-g12a-x96-max-no-cvbs.dts changing max-frequency to 150000000 and adding this new lines copied from meson-g12a-u200.dts: mmc-ddr-1_8v; mmc-hs200-1_8v; Now the emmc performance on beelink is around 95MB/s and remains working without issues. Anyone know what these lines do and if they are safe to use? Thanks
