Hi all,
Successfully Installed Armbian_20.02.1_Nanopineo2black_buster_current_5.4.20.img on a NanoPi Neo2 Black using an SD Card. The board is fitted with a 16GB eMMC card via the optional adapter.
Ran apt-update && apt-upgrade && armbian-config (“Install” “Install to/update boot loader” -> Install/Update the bootloader on SD/eMMC" - that was the only option available.)
Proceeded with 'nand-sata-install' only to be presented with the same 'Install/Update the bootloader on SD/eMMC' and nothing else.
Poked about, no mention of the eMMC card during boot (via dmesg) and no '/dev/mmbblk1' - which I thought might be the appropriate device.
Checked the eMMC card using a microSD adaptor on another machine - shows up as a device so suspect it's okay for use.
Have scanned the forum and found similar instances where eMMC support hasn't been enabled. Patches are available for those systems and look to have been implemented. Was wondering is someone far more knowledgeable than myself could confirm if eMMC support is enabled in the image I installed and if not, outline the steps needed to enable it.
Thanks in advance, -- Adrian
