Just had another crash. Unable to upload armbianmonitor -u, so here I attached armbianmonitor -U here.
I found the /sys/class/thermal zone for temperature. While I monitored it, the temperature was highest at 69.x C in zone0, and 65.x C in zone0.
ip link set eth0 down & ip link set eth0 up was able to bring back the network.
However, the system became very slow and nearly unusable. Then after a few minutes, the system crashed totally. I had to power off and on in order for the system to be normal.
After system reboots, the temperature is 42 C. Not sure if it is the high temperature causing the issue. Any other way to troubleshoot?
Thanks
armbianmonitor.txt
