w0ndersp00n
26 -
Thanks for this Too bad in no cases my C2 wants to boot up I guess I should burn a new image all together. I still don't understand what went wrong during that last update... Guess I'm happy that I still can access the files on the eMMC card.
A few weeks ago, after a firmware-upgrade my C2 bricked. It's blue led didn't flash any more and no serial console was available. Since I had everything setup just right I wanted to recover it using these steps here: https://docs.armbian.com/User-Guide_Recovery/#replacing-boot Off course I replaced the packages with the ones for the C2. Specifically: https://mirrors.dotsrc.org/armbian-apt/pool/main/l/linux-5.9.14-meson64/linux-dtb-current-meson64_20.11.3_arm64.deb https://mirrors.dotsrc.org/armbian-apt/pool/main/l/linux-5.9.14-meson64/linux-image-current-meson64_20.11.3_arm64.deb https://mirrors.dotsrc.org/armbian-apt/pool/main/l/linux-buster-root-current-odroidc2/linux-buster-root-current-odroidc2_20.11.6_arm64.deb https://mirrors.dotsrc.org/armbian-apt/pool/main/a/armbian-firmware/armbian-firmware_20.11.3_all.deb After following all the steps, I don't seem to have an uInitrd. I don't know if that would help booting up again, but from the symlinks section it's the only file missing after following all the steps: Does anybody know what went wrong or guide me towards the right steps to recover my C2?
Hi, No haven't had any progress as an Armbian firmware upgrade broke my C2 :( Currently still working on getting it back up and running without a new install but I don't seem to succeed...
Well, my C2 doesn’t seem to have a console so I guess I need to recover it another way. My N2 thankfully didn’t crash after the update. It had a power outage... I’ll check out the autotests later. Need to deal with some private stuff first, then recover the C2 and then I’ll be able to get tinkering again.
It seems I was too late to notice this topic. My C2 “died” as well, as it no longer boots. I didn’t have a backup script in place yet. I’ve ordered an UART cable, which should arrive this week. Hopefully I understand how this work and be able to resurrect Armbian. I’ll just need to make sure not to reboot my N2, since I updated it as well, but didn’t reboot yet.
Odroid C2 - Ethernet randomly gets disconnected
w0ndersp00n replied to w0ndersp00n's topic in Amlogic meson
That's strange - it only happens to my new Armbian installs. But I've assigned static IP Addresses for now, to see if that fixes this issue -
With my OPi Zero, I noticed that at random times the ethernet connection somehow gets disabled. The only way to recover is by power cycling. I use the device as Pi-Hole (so when ethernet gets disconnected, I don't have internet anymore), print server and UniFi controller. I decided to swap it for my Odroid C2. Odd enough the C2 has the same issue. Maybe someone can help me with this? When powercycled, the Odroid with the latest Armbian (installed two days ago) is all up and running fine. It can connect to the internet, I can SSH into it. The ethernet led is flashing orange, so the gigabit connection is available. However, at rondom times the ethernet leds are both disabled. At this point, the C2 is still alive, but there's no way to access it without power cycling. I've tried removing the ethernet cable and connecting it again, hoping Armbian would recognize the connection - what happens in this case is that the green led will flash a few times (100Mbit) but the device is still offline. I've added some information from the log here before rebooting. This information keeps repeating in the log files... Hopefully someone can guide my as how to get the connection stable.
I never heard of Teedy before... It has a beautiful UI though. But considering it's written in Java, I can't call it lightweight. Every Java app I run uses about 6 times the amount of memory compared to Python apps. Rust or C/C++ would be best, considering most ARM boards don't get more than 4GB's of RAM. I might try it out on an old C2, to get a feeling of how it compares to the other ones.
In general, a lot of things are not documented or are documented as comments within the code and config files. So besides the documentation, you need to read the code and config files to figure out how everything works. This is a small package, but probably not worthwile since it's only helpful for storing text-based documents, which isn't the core. True, but it doesn't fix the fact that the database is locked during operations, making it sometimes annoying to work with Paperless. I'm going to find out if it is possible to use MariaDB or PostgreSQL, since they only lock records and not the complete database for writing. I didn't, it's not documented. I've read the docker documentation and found out how I was able to use my own locations for volumes. I'll upload my docker-compose.yml sometime. Yes, the scanned documents are still 300dpi. I actually think it is 600dpi in my case. Yes, some people are trying this, but it isn't very easy since Paperless in it's core wasn't designed for this. You should probably place the script in a folder on your host and then use file mapping to map a file from the host to the container: https://docs.docker.com/compose/compose-file/#volumes
In my case `disable-notify` is needed, because my consume folder is on a NFS-network location. inotify doesn't work on network locations, so new files would never be processed. Because I'm using NFS, rights are not an issue (if you set the UID and GID to the same from the NFS server.) Regarding the date: in the Netherlands we use DMY dates. I noticed that Paperless wouldn't detect any correct date when this was set to YMD. I guess this idea is nice, but I still don't understand how that script would be able to define the correct filename. E.g. my scanner scans to my NAS and it sets a default filename, which always is the serial number of the scanner, appended with a number. So ABC7483393939_000001.pdf. There would be no way for any software to know what this file is. So that's where Paperless and OCR come in, reading and automatically tagging it. I guess the only way to make this work, is to indeed scan to a 'pre-Paperless' location and pre-process it. Paperless however does support POST-OCR scripts, so maybe it would be worthwile to check that out. I assume you can change the Title (Filename) of the consumed file, based on the OCR results: https://paperless.readthedocs.io/en/latest/consumption.html#hooking-into-the-consumption-process https://github.com/the-paperless-project/paperless/blob/master/scripts/post-consumption-example.sh Yes, so in the match field I've added `mediamarkt "media markt" redcoon`, so all scans containing those strings will automatically be assigned to correspondent MediaMarkt.
This is the same with Paperless as it is with Mayan. By setting the restart policy in the docker-compose file or in the docker run command. I use “unless-stopped”.
I haven’t tested exporting documents yet. I did notice that when downloading a file, the filename will become ‘Date of the file_Title of document’. Title of document is the original filename, if you didn’t change it. Documentation regarding exporting all files: https://paperless.readthedocs.io/en/latest/utilities.html#the-exporter I’ve been using Paperless for a few moments now and I have to say it really seems to be what I was looking for. On a technical level I’ve seen that the documents are saved with numeric filename (00000010.pdf), while Mayan uses UIDs. I don’t know which is better, but since Paperless seems to have quite a large community of home users, I assume that any issues regarding this would’ve been noticed by now.
So after playing around with Paperless for a few hours and with a few testruns, I have to admit I'm starting to get more positive. The downside still is that documentation is lacking and that development seems slowed down quite a bit. On the plus side, when you know what to do, this tool can work very well for you. Some less positive points: It doesn't support Office-type of files. So no docx, odt, xlsx, etc. This issue isn't too big, since I'm using it mostly for files I received/scanned. And if I receive an Office-type of document, it isn't very hard converting it to PDF. It does support TXT, CSV and MD files. However, the default Dockerfile doesn't account for this functionality. So you'll need to add 'ghostscript-fonts' to the added packages, or add it to the consumer container manually afterwards if you want to use this. While consuming, it's impossible to add new tags or correspondents due to SQLite being locked. Some more positive points: By additionally mounting paperless.conf via the volumes in both containers, a lot of configuration changes can be made. And easier then sh-ing into the containers. E.g. encryption of saved files can be enabled You can set the date order (default YMD, I set it to DMY) This is very worthwile, because with this, Paperless will read the OCR'ed file and detect the date of the file. I successfully tested this with some invoices. You can set the default language for tesseract. I set it to Dutch, and this really speeds up the process of consuming documents, instead of trying English first, before any other languages. Also I've set the OCR quality to 150dpi instead of 300dpi, which also helps speeding up the OCR process. Since my scanner is high quality, I don't assume this will become an issue. And most important: you can enable "forgiving OCR", which means that a file is consumed, even if OCR failed! In tags and correspondents you can set some Match keywords to search for. If Paperless finds those, the correspondent and or tags will automatically be added to the consumed document. I added an invoice from a retailer, and after consuming, the date was correct, the correspontent was correct and the right tags were added I'm going to scan some files and upload them to my development box to test if everything will still work as expected. If it does, I might replace Mayan wih Paperless. Edit: In the image you can see two POS-tickets I scanned, which were from 2015. Paperless automatically found the correct correspondent, MediaMarkt. In the first run I tried to see if it would automatically find the correct date (July 2), which was correct. On the second run I wanted to know if automatic tagging worked (bon), and that worked. It isn't flawless, especially with these POS-tickets degrading over time. E.g. for some IKEA tickets Paperless was unable to determine the correct date. I guess that this issue will be smaller with recent tickets without the amount of degradation these have.
It’s true that initial setup of Paperless is quite ok. However, as you noticed, you have to use the command line in order to change settings and setup the user. Basically everything to setup happens via the CLI. In my case I also had to disable inotify. This is once again a specific setting which needs to be changed before starting the container, because otherwise it would never detect any of my files in the consume directory. The consumption process on my side is also less reliable than with Mayan. It’s very slow. Where Mayan processes a PDF including OCR with in seconds I need to wait minutes on Paperless When Paperless is unable to execute OCR or detects a language for which you haven’t installed tesserae-ocr, than the consumption fails and your document is never added. There is no way to override it. Because of some reason Paperless thought one of my documents was in Portuguese, so it simply doesn’t process it. It’s impossible to add files other that PDF, JPG and TIFF. Mayan will convert DOCX and ODT to PDF while processing the file. On the other hand: Paperless gives me the ability to quickly search on correspondent, date and text in the file which is the basic functionality I’m looking for. This works out of the box, while you need to configure this with Mayan. So I’m still very much on the fence regarding Paperless... I still prefer=er Mayan, but it’s resource requirements are out of the roof... So neither Mayan or Paperless will (by default) rename files. Mayan will not do that, because it’s Metadata-driven. You should use metadata and I think you can setup rules to add specific metadata when some text has been found in the OCR data. Paperless can’t do that, but when reading the manual, you probably can write a hook function in order to do that after the consumption. Also most DMS systems can export all files, I’d desired, using specific naming conventions. I have seen this application as well indeed. But my biggest gripe is that it tries to be a file system, with conventions such as folders. For my the file names are irrelevant. My requirements are: Categorise on sender (correspondent) Categorise on type of document (tagging) OCR Search on date, correspondent, tag and document text I don’t want another file system. I want to use metadata in order to find my files. So with these requirements Paperless should be a fit, but I’m still not liking the small issues I’ve found until now. Edit: I just found out about https://github.com/the-paperless-project/paperless/blob/1c956652f360e58409c8fca148b7662585dd1087/paperless.conf.example. Maybe this file should be added to volumes in order to change settings somewhat more easy.
I don't know why it failed. But here are the steps I took to get Paperless running next to Mayan on my dev/test Odroid: git clone https://github.com/the-paperless-project/paperless.git cd paperless cp docker-compose.yml.example docker-compose.yml cp docker-compose.env.example docker-compose.env docker-compose up -d I edited docker-compose.env to change variables for Timezone and OCR Languages: TZ=Europe/Amsterdam PAPERLESS_OCR_LANGUAGES=nld deu eng With these steps, Paperless will be build and run on port 8000. This process takes about 15 minutes on my Odroid C2. Maybe you can try again with these steps. One thing I did notice already: the consumption of PDF files takes waaaay longer with Paperless then with Mayan. But in my short test this application actually seems worthwile. I'm going to test it further as well.
