kimwida
13 -
Sorry for my lack of knowledge. I am using Armbian 20.08.5 Buster. So you mean I should start from debian-ARM64 docker image? When I run debian-ARM64 docker image, there isn't even "ifconfig". So I should add all stuff and commit to make an image right? The reason to use docker is for backup my successful system because I like to mess up my rockpis with many things.
Hi. I am running OpenVPN, Samba and Plex with Armbian on my rockpis. I want to make a docker image from it. I am new to docker and I searched and found that I could make an image from Docker file or commiting in a container. I thought that commiting in container was easier for me. So I downloaded "twhtanghk/armbian" in docker hub and ran it. #docker container run -it twhtanghk/armbian bash But when I hit "#ls -ls /dev" in the container, it show different result with my rockpis' Armbian. So I am reluctant to start to install those. Is it ok to install OpenVPN, Samba and Plex with the image? Or which docker image should use? And is there any way to make a docker image from my present Armbian?
Sadly, I have to choose "yes" at first and then "no". Now I have to wait and hit "Enter" for samba install. But it saves a lot of time for me. Anyway thank you, I solved a lot of problems from your replies.
Hi. I am digging many things with armbian so I install fresh armbian and many applications so many times. So I am making a long script to install many applications and edit many configuration. When it asked "Yes/On" on text prompt, I use "#echo yes | apt install vim". It works well. But when I install samba, it ask text prompt "yes/no" at first and then with dialog box "yes/no". So I tried "#echo yes | echo no | apt install samba". But it doesn't work. How can I send "yes/no" to dialog box in bash shell??
Hi. I am trying to use bluetooth with my rock pis but I can't with armbian but debian. With debian I just followed this page and it works. https://wiki.radxa.com/RockpiS/Debian#Bluetooth But I want to work it in armbian. I turn bluetooth on in armbian-config. But "hciconfig" have no result and when I power on bluetooth, it say "No default controller available". So I searched and found it. Is it mean that I need to build a kernel to use bluetooth??
I searched and found solution. After install fresh armbian, I added this to "/etc/network/interfaces" auto wlan0 allow-hotplug wlan0 iface wlan0 inet manual wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf iface default inet static address 2.1.1.38 netmask 255.255.255.0 gateway 2.1.1.1 dns-nameservers 168.126.63.1 168.126.63.2 wireless-mode Managed wireless-power off
I don't know why but my rock pis can't fix mac even adding the line. Booting with new debian and armbian with new SD card have same result. I think my rock pis went wrong with my pwm things...
I found a workaround. After boot, p2p0 connection is alive. But each booting make its ip address grow. So I changed it fixed ip like it. #ifconfig p2p0 down #ifconfig p2p0 2.1.1.38 netmask 255.255.255.0 up #route add default gw 2.1.1.1 then, I can use wifi with p2p0. So I add these commands into "rc.local". ifconfig p2p0 down ifconfig p2p0 2.1.1.38 netmask 255.255.255.0 up route add default gw 2.1.1.1 sleep 10 dhclient p2p0
Hi. I was testing pwm with a motor, then my rock pis stopped. After boot, I couldn't see wlan0 in nmtui-connect. So I reinstall fresh armbian, I can see wlan0 again. I do wifi setting with nmtui-connect but after rebooting I can't connect wifi. I have to redo wifi setting with nmtui-connect, put password again and it adds another wifi. It seems like it can't connect to previous wifi. When I do "nmcli con show", I can see the previous wifi but it is deactive. I searched about it and found wifi mac address randomization issue. So I checked "10-override-random-mac-disable.conf". [connection] wifi.mac-address-randomization=1 [device] wifi.scan-rand-mac-address=no Whenever I redo nmtui-connect, it add file count in "/etc/NetworkManager/system-connections" Is there any way to solve it? Or pwm thing break wifi chips??
Hi. I have been playing with relay and gpio and having a lot of fun. Now I want to use pwm to control a fan. So I edit "/boot/hw_intfc.conf". ..... intfc:pwm2=on intfc:pwm3=on .... And I reboot it. But I can't see "/sys/class/pwm/pwmchip2" and "/sys/class/pwm/pwmchip3" What else should I do??
Hi. I am kind of linux newbie. I want to use serial console with my Rock Pi S thru usb otg. I googled and found this from https://gist.github.com/lukicdarkoo/a87f79b1c25cd86bdc47a8784d6eee9c. I tried it but failed. And I found that there was not "sunxi_usb_duc" directory. Any advice would be apreciated. =============================== ok, I just found that these are for orange pi. Any guide for rock pi s? =============================== After install new image, now I can use serial console with usb otg.
