I am trying to investigate why borg backups, specifically when doing borg check, are taking over twice as long on armbian buster + OMV5, compared to armbian stretch + OMV4. The borg server is an Odroid HC2, and borg check runs on the server (HC2) and is single threaded.
Not sure where to even start, but one thing that caught my attention is that the borg process will be running at 100% CPU at various times (as expected), but the CPU frequency at those same times was reported at 200-300 MHz when observed using htop. Is this normal? Unfortunately I don't know what frequency was normal in the same circumstances with armbian stretch + OMV4.
Benchmarks done by armbian-config show the CPU at 2000 MHz or a bit less as the passively cooled CPU throttles a bit over extended loads:
Throttling statistics (time spent on each cpufreq OPP) for CPUs 4-7:
2000 MHz: 3526.66 sec
1900 MHz: 4.97 sec
1800 MHz: 9.55 sec
1700 MHz: 9.22 sec
1600 MHz: 37.34 sec
1500 MHz: 73.44 sec
1400 MHz: 77.32 sec
1300 MHz: 5.47 sec
1200 MHz: 0 sec
1100 MHz: 0 sec
1000 MHz: 0 sec
900 MHz: 0 sec
800 MHz: 0 sec
700 MHz: 0 sec
600 MHz: 0 sec
500 MHz: 0 sec
400 MHz: 0 sec
300 MHz: 0 sec
200 MHz: sec
I can provide the output of armbianmonitor -U or parts of it if it would help, though at 17000+ lines, pastebin didn't like it. There seem to be a bunch of duplicated sections. armbianmonitor -u said "Network/firewall problem detected. Not able to upload debug info."
