Hi folks,
I'm using a NanoPi Neo 2 with Armbian Buster but I think my problem does not relate to this specific hardware.
I wanted to update my Pi today, so I ran:
> sudo apt update
Hit:1 [... and so on]
Reading package lists... Done
Building dependency tree
Reading state information... Done
1 package can be upgraded. Run 'apt list --upgradable' to see it.
and
> sudo apt list --upgradable
Listing... Done
hostapd/buster 3:2.9-101~armbian20.05.0-trunk+1 arm64 [upgradable from: 3:2.7-99~armbian5.86+1]
N: There are 4 additional versions. Please use the '-a' switch to see them.
But I could not upgrade. It says there are no packages available. So I ran:
> sudo apt install hostapd
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
hostapd : Depends: libssl1.0.0 (>= 1.0.2~beta3) but it is not installable
E: Unable to correct problems, you have held broken packages.
Today I updated Pi-Hole and yesterday I activated unintended-upgrades (security updates) by editing /etc/apt/apt.conf.d/02-armbian-periodic. I also executed the following command: sudo dpkg-divert --no-rename --add /etc/apt/apt.conf.d/02-armbian-periodic
So there is something broken but I don't know what and how I can fix it. I hope you can help me. Thanks in advance.
