I can not raise the Access Point. Already my head is spinning on the number of tried recipes from the Internet. Service information here. Help me please.
Configuration files: /etc/hostapd.conf
ssid=BananaPI-WiFi
interface=wlan0
hw_mode=g
channel=5
bridge=br0
driver=nl80211
logger_syslog=1
logger_syslog_level=2
wmm_enabled=1
wpa=2
preamble=1
wpa_psk=c86e997b3dceff9bd7ffaf3f7353099a301c2**********d10a892c33cafcb5db
wpa_passphrase=10********IV
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
auth_algs=1
macaddr_acl=1
noscan=0
### IEEE 802.11n
#ieee80211n=1
#ht_capab=
#country_code=US
#ieee80211d=1
### IEEE 802.11n
### IEEE 802.11a
#hw_mode=a
### IEEE 802.11a
### IEEE 802.11ac
#ieee80211ac=1
#vht_capab=[MAX-MPDU-11454][SHORT-GI-80][TX-STBC-2BY1][RX-STBC-1][MAX-A-MPDU-LEN-EXP3]
#vht_oper_chwidth=1
#vht_oper_centr_freq_seg0_idx=42
### IEEE 802.11ac
# controlling enabled
ctrl_interface=/var/run/hostapd
ctrl_interface_group=0
/etc/dnsmasq.conf
interface=wlan0 # Use interface wlan0
listen-address=192.168.42.1 # Explicitly specify the address to listen on
bind-interfaces # Bind to the interface to make sure we aren't sending things elsewhere
server=8.8.8.8;192.168.1.101; # Forward DNS requests to Google DNS
domain-needed # Don't forward short names
bogus-priv # Never forward addresses in the non-routed address spaces
dhcp-range=192.168.42.10,192.168.42.100,24h # Assign IP addresses between 172.24.1.50 and 172.24.1.150 with a 12 hour lease time
/etc/resolv.conf
nameserver 127.0.0.1
/etc/dhcp/dhcpd.conf
ddns-update-style none;
authoritative;
subnet 192.168.42.1 netmask 255.255.255.0 {
range 192.168.42.10 192.168.42.100;
option broadcast-address 192.168.42.255;
option routers 192.168.42.1;
default-lease-time 600;
max-lease-time 7200;
option domain-name "local";
option domain-name-servers 8.8.8.8, 8.8.4.4;
/etc/default/isc-dhcp-server
INTERFACESv4="wlan0"
INTERFACESv6="wlan0"
/etc/network/interfaces
source /etc/network/interfaces.d/*
# Network is managed by Network manager
auto lo
iface lo inet loopback
#auto eth0
# iface eth0 inet dhcp
allow-hotplug eth0
iface eth0 inet static
#alow-hotplug eth0
address 192.168.1.102
gateway 192.168.1.101
dns-nameservers 192.168.1.101
#auto wlan0
#iface wlan0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet static
address 192.168.42.1
auto wlx000da31d4105
iface wlx000da31d4105 inet dhcp
wpa_ssid STP_NET
wpa_psk 10********63
#wpa-conf /etc/network/wpa_supp.conf
#wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
/etc/network/interfaces.d/armbian.ap.nat
allow-hotplug wlan0
network 192.168.42.0
broadcast 192.168.42.255
network={
#proto=WPA2
#pairwise=CCMP TKIP
key_mgmt=WPA-PSK
#priority=5
scan_ssid=1
ssid="STP_NET"
#bssid=30:0c:23:bf:8c:1a
#psk=97dbbf104f1f1e4e4ec61ab84b2adc40af*************e3161a6fa4b56da911
psk=10********63
#network={
# ssid="STP_NET"
# psk="***********"
# psk=97dbbf104f1f1e4e4ec61ab*******************38ae3161a6fa4b56da911
/etc/NetworkManager/system-connections/Armbian ethernet.nmconnection
[connection]
id=Armbian ethernet
uuid=722668d8-a507-423c-9d76-3a009a652da2
type=ethernet
interface-name=eth0
permissions=
timestamp=1589196940
[ethernet]
mac-address-blacklist=
[ipv4]
address1=192.168.1.102/24,192.168.1.101
dns=8.8.8.8;192.168.1.101;
dns-search=
method=manual
route-metric=78
[ipv6]
addr-gen-mode=stable-privacy
dns-search=
method=auto
/etc/NetworkManager/conf.d/armbian-default-metric.conf
[connection-ethernet-gateway]
match-device=interface-name:eth0
ipv4.route-metric=50
[connection-wifi-other]
match-device=type:wifi
# add row
match-device=interface-name:wlan0
ipv4.route-metric=88
[connection-ethernet-other]
match-device=type:ethernet
ipv4.route-metric=77
