Greetings, as noted in the title I have a Plus 2E and I am trying to use the built in wifi to enable a wifi access point. I followed the instructions and video which recommended using armbian-config to create a hotspot. That utility failed to create the hotspot so I ran hostapd manually to find the issue and the following errors were reported (I will attach a file with complete output:
ioctl[RTL_IOCTL_HOSTAPD]: Operation not supported
wlan0: Could not connect to kernel driver
I spent a couple hours searching and it seems related to the driver support AP mode. I haven't gone down the hole of trying to rebuild the driver yet because I'm not sure what options would be needed to function correctly. Does anyone have any insight as to why this isn't working or what can be done to get a hotspot running in AP mode on an OrangePi Plus 2E? Thanks!
2020051401-hostapd-output.txt
