Tried both Debian and Ubuntu based 23.5 releases on my v1.4 board
	Boot process stops at "Starting kernel..."
	Also tried the "minimal CLI" debian release with same results.
	The previous versions 23.02 are fine.
U-Boot SPL 2022.07-armbian (May 27 2023 - 19:26:49 +0000)
DRAM: 512 MiB
Trying to boot from MMC1
U-Boot 2022.07-armbian (May 27 2023 - 19:26:49 +0000) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi Zero
DRAM:  512 MiB
Core:  65 devices, 17 uclasses, devicetree: separate
WDT:   Not starting watchdog@1c20ca0
MMC:   mmc@1c0f000: 0, mmc@1c10000: 1
Loading Environment from FAT... Unable to use mmc 0:1...
In:    serial
Out:   serial
Err:   serial
Net:   phy interface1
eth0: ethernet@1c30000
starting USB...
Bus usb@1c1a000: USB EHCI 1.00
Bus usb@1c1a400: USB OHCI 1.0
Bus usb@1c1b000: USB EHCI 1.00
Bus usb@1c1b400: USB OHCI 1.0
Bus usb@1c1c000: USB EHCI 1.00
Bus usb@1c1c400: USB OHCI 1.0
scanning bus usb@1c1a000 for devices... 1 USB Device(s) found
scanning bus usb@1c1a400 for devices... 1 USB Device(s) found
scanning bus usb@1c1b000 for devices... 1 USB Device(s) found
scanning bus usb@1c1b400 for devices... 1 USB Device(s) found
scanning bus usb@1c1c000 for devices... 1 USB Device(s) found
scanning bus usb@1c1c400 for devices... 1 USB Device(s) found
       scanning usb for storage devices... 0 Storage Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot/boot.scr
4121 bytes read in 3 ms (1.3 MiB/s)
## Executing script at 43100000
U-boot loaded from SD
Boot script loaded from mmc
184 bytes read in 3 ms (59.6 KiB/s)
15848831 bytes read in 658 ms (23 MiB/s)
8477464 bytes read in 355 ms (22.8 MiB/s)
Found mainline kernel configuration
35377 bytes read in 7 ms (4.8 MiB/s)
504 bytes read in 6 ms (82 KiB/s)
Applying kernel provided DT overlay sun8i-h3-usbhost2.dtbo
Applying kernel provided DT overlay sun8i-h3-usbhost3.dtbo
617 bytes read in 6 ms (99.6 KiB/s)
Applying kernel provided DT overlay sun8i-h3-tve.dtbo
4185 bytes read in 6 ms (680.7 KiB/s)
Applying kernel provided DT fixup script (sun8i-h3-fixup.scr)
## Executing script at 45000000
Kernel image @ 0x42000000 [ 0x000000 - 0x815b18 ]
## Loading init Ramdisk from Legacy Image at 43400000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    15848767 Bytes = 15.1 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 43000000
   Booting using the fdt blob at 0x43000000
EHCI failed to shut down host controller.
   Loading Ramdisk to 490e2000, end 49fff53f ... OK
   Loading Device Tree to 49071000, end 490e1fff ... OK
Starting kernel ...
