69 -
petrmaje's Achievements
Hi, the situation with Lamobo is very bad. I understand reasons, why you drop support for the board, but you should provide last working configuration for possible upgrades. All devices with next kernel will die after apt-get upgrade. This happened to me today. In archive is nothing working with kernel 4.x, which I need. So is it possible remove R1 from build target and in download section offer last 4.x kernel with switch support? And block kernel upgrade using apt? Thanks, Petr
1.29 is good and stable, it was big step forward from previous version.
Everything depends on what do you need. I required two 1280x720 cameras at 10FPS, three 640x480. The reason was, that our old dual core xenon server was overloaded, so I tried to move the system to ARM. But generally, if you dont need so high framerate, one board should be enough for several cameras. For zoneminder is one important rule - more cores are better Other things you can tune up by software. Thats my experience. But finally I replaced dual core xenon by quad core xenon and the system load drops down to 10%. PM
Hi, I tested zoneminder a time ago with two RPI3 as image processing and Lamobo R1 as storage and SQL server and results was really nice But it's not easy to configure it the right way See printscreen! PM
Try to compile it from source. It is easy with armbian, everything is preinstalled and you don't need to wait for somebody to fix it. Or, did you find another solution?
It seems to be ok: root@TVheadend:~# cat /etc/apt/sources.list.d/tvheadend.list deb https://dl.bintray.com/tvheadend/deb wheezy release root@TVheadend:~# In the meantime I compiled tvheadend from source, but I have another issue with uploading firmware to USB dongle: [ 8.725304] dvb-usb: found a 'Leadtek WinFast DTV Dongle Gold' in warm state. [ 8.733722] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer. [ 8.744609] ERROR: 256 KiB atomic DMA coherent pool is too small! [ 8.744618] Please increase it with coherent_pool= kernel parameter! [ 8.751888] dvb-usb: Leadtek WinFast DTV Dongle Gold error while loading driver (-12) [ 8.757347] dvb_usb_af9015: probe of 1-1.2:1.0 failed with error -12 [ 8.762924] usbcore: registered new interface driver dvb_usb_af9015 I am googling about it ... Kernel 4.4.1-sunxi has no problem with uploading firmware ....
Hi, I am trying to install TVheadend using Debian-micro-home-server, but no success. Armbian Wheezy with legacy kernel. See printscreen. Any idea? PM
Hi Patcher, you are absolutely right! Take a look on the second picture, A20 without heatsink
Hardcore solution :-))
FYI: Armbian running on A31s based Banana Pi M2
petrmaje replied to tkaiser's question in Allwinner sunxi
Hi Tkaiser, USB-to-Ethernet dongle is not the only solution. People with PPPoE are without problems, as the people with tagged wan. If you have a switch at home with two unused ports, you can tag your wan and everything should be ok. PM -
Hi Rui, it looks impresive, but I had similar results with some drivers a time before. How many devices do you have connected to the AP? Try to connect for example 3 or 4 wifi devices, some of the far from the AP and generate network traffic simultaneously. If your driver will handle it without speed drop to minimum, congatulations!!!! Petr
solved GMAC TX status: VLAN frame
petrmaje replied to petrmaje's topic in Advanced users - Development
Ok, I will let it run as it is. Thanks. -
The question is, if the device will overlive till evening. System is running on SD card and HD is only for data. Is the linux log so clever, that when there is no space for logging will flush logfiles? -
Hi, after pure installation Armbian_4.5_Lamobo-r1_Debian_wheezy_3.4.109.zip, the log is full of GMAC messages: [43099.518189] GMAC TX status: VLAN frame [43099.521192] GMAC TX status: VLAN frame [43099.524646] GMAC TX status: VLAN frame [43111.775611] GMAC TX status: VLAN frame [43112.963963] GMAC TX status: VLAN frame [43112.980989] GMAC TX status: VLAN frame [43112.986370] GMAC TX status: VLAN frame [43112.989681] GMAC TX status: VLAN frame [43112.992410] GMAC TX status: VLAN frame [43112.996184] GMAC TX status: VLAN frame [43113.002038] GMAC TX status: VLAN frame [43113.973308] GMAC TX status: VLAN frame [43113.976078] GMAC TX status: VLAN frame [43114.143583] GMAC TX status: VLAN frame [43114.487643] GMAC TX status: VLAN frame [43114.700444] GMAC TX status: VLAN frame [43115.015755] GMAC TX status: VLAN frame [43115.188027] GMAC TX status: VLAN frame Bug? Or I configured something wrong? PM
