Alright, I got it, thank you! I commented out all the lines in the syncToDisk function (in log2ram code) and replaced them with one "echo "Ok"" (since it was giving me some strange error when I left it all blank). It works like magic! I now modified the log2ram code to give the user an option in the configuration file to do this (i.e. to never write the logs back to the disk). We'll see if he accepts my pull request.
Regarding the other issue, logrotate could rotate the logs in the /var/log tmpfs partition in RAM, so that if the computer is running for many days straight, the 40 MB partition shouldn't fill (note: under my arrangement, when the computer reboots /var/log empties anyway - with the exception of the boot log). If it does fill, I could always set logrotate to run more frequently or save fewer logs.
Thanks again!
Isaac
