3 -
I have move system to emmc, and want to use sdcard to storage videos from camera. So I want to sdcard can automount/umount after hotplug. I have try to use udev to fulfill it. But it seems not work. I add a rules for udev at /etc/udev/rules.d: ACTION=="add",KERNEL=="mmcblk2p1",RUN+="/etc/udev/sdcard_hotplug.sh add /home/opi/Videos/sdcard %k" ACTION=="remove",KERNEL=="mmcblk2p1",RUN+="/etc/udev/sdcard_hotplug.sh remove /home/opi/Videos/sdcard %k" And add a shell file at /etc/udev/sdcard_hotplug.sh #!/bin/bash case $1 in add) mkdir -p $2 mount -t exfat -o iocharset=utf8,rw,sync,umask=0000,dmask=0000,fmask=0000 /dev/$3 $2 ;; remove) umount $2 rm -rf $2 ;; esac Add chmod a+x for it. Test it ok. But udev seems not work! I have use udev monitor to test if remove and insert sdcard can generate event. It works. And use udevadm test, and it also ok. Anybody can help me?
Hi, Just as my last post. I want to know if it is possible to wakeup opi3 after I switch its state to "mem" or "disk" using gpio on CON12. I have doing some reasch but I don't know if it is right: PL/PM port can be used as wakeup source. PF/G/H/L/M port support interrupt event. PC/D didn't support interrupt. But when I try to write a device tree file, but it just report some error with error code -22. My device three is like this: /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h6"; /* * This fragment is needed only for the internal pull-up activation, * external pull-up resistor is highly recommended if using long wires */ fragment@0 { target = <&r_pio>; __overlay__ { gpio_key_wakeup: gpio_key_wakeup { pins = "PL8"; function = "gpio_in"; bias-pull-up; }; }; }; fragment@1 { target-path = "/"; __overlay__ { gpio-keys-user { /* * Use "gpio-keys" for EINT capable pins, "gpio-keys-polled" for other pins * add "poll-interval" property if using "gpio-keys-polled" */ compatible = "gpio-keys"; autorepeat; pinctrl-names = "default"; pinctrl-0 = <&gpio_key_wakeup>; key_wakeup{ label = "GPIO KEY_WAKEUP"; linux,code = <143>; /* KEY_WAKEUP, see include/uapi/linux/input-event-codes.h */ gpios = <&r_pio 0 8 1>; /* PL8 GPIO_ACTIVE_LOW */ }; }; }; }; }; I am still a newbie and I don't know enough thing about how to write the right DTS file. Please give me some help. Thanks (I have tested KEY_POWER it seems everything OK. I don't know what is the error part about KEY_WAKEUP) ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~` Finally, I fulfill it now. dts is like this: one pin for sleep: /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h6"; /* * This fragment is needed only for the internal pull-up activation, * external pull-up resistor is highly recommended if using long wires */ fragment@0 { target = <&pio>; __overlay__ { gpio_but_sleep: gpio_but_sleep { pins = "PH3"; function = "gpio_in"; bias-pull-up; }; }; }; fragment@1 { target-path = "/"; __overlay__ { gpio-keys-user { /* * Use "gpio-keys" for EINT capable pins, "gpio-keys-polled" for other pins * add "poll-interval" property if using "gpio-keys-polled" */ compatible = "gpio-keys"; autorepeat; pinctrl-names = "default"; pinctrl-0 = <&gpio_but_sleep>; sleep_button { label = "KEY_SLEEP"; linux,code = <142>; /* KEY_SLEEP, see include/uapi/linux/input-event-codes.h */ linux,input-type = <1>; // EV_KEY gpios = <&pio 7 3 1>; /* PD15 GPIO_ACTIVE_LOW */ gpio-key; }; }; }; }; }; one pin for wakeup: /dts-v1/; /plugin/; / { compatible = "allwinner,sun8i-h3"; fragment@0 { target = <&pio>; __overlay__ { poweroff_pins:poweroff_pins { allwinner,pins = "PA13"; allwinner,function = "gpio_out"; }; }; }; fragment@1 { target-path = "/"; __overlay__ { poweroff: poweroff { compatible = "gpio-poweroff"; gpios = <&pio 0 13 1>; }; }; }; }; But some weird things happend: after I wakeup again. I can connect to opi3 via debug port(uart0). But can not connect it from ssh again. Even after I setup a new static ip for it. And when I test "who", I find it still connect with the old ssh. But when I try to ping gatway "ping 192.168.1.1": it show: From 192.168.1.108 icmp_seq=1 Destination Host Unreachable It is so wried.
Hi, I want to use a gpio in CON12 to wakeup orange pi 3. But I can not figure it out. I am using armbian 5.4.43. I have done some researh about this question. It seems the basic process shoule be: 1、choose the right pin to wakeup. Cause some pins can not support interrupt and wakeup event. But I can not find which gpio support wakeup event. It seems I should choose pin on PL or PM ports. But according the schmatic, lots of them have been used as other usages: PIN DEFINE CFG PL0 PMU-SCK 3 PL1 PMU-SDA 3 PL2 RECOVERY 2 PL3 LINK-LED 1 PL4 POW-LED 1 PL5 USB0-DRVVBUS 1 PL6 MUTE 1 PL7 STATUS-LED 1 PL8 PL9 IR-RX 2 PL10 BT-WIFI-ON 1 PM0 WL-WAKE-AP 0 PM1 BT-WAKE-AP 0 PM2 AP-WAKE-AP 1 PM3 WL-REG-ON 1 PM4 BT-REG-ON 1 It seems only PL8 isavailable, but PL8 is also used as PWM pin 2、 write a dts file and let it using gpio-keys driver. For examples choose KEY_WAKEUP. But There need more detail about how to write dts files even after I read some examples. I don't know if I should choose "&pio" or "&r_pio". I can not find any file descript this part. (I have found some descriptiion about PL port and others. &pio is used for PA~PK, &r_pio is used for PL port. And Only Pins on PL port can be used as wakeup source.) (I have test PL8 and PL10. All of them return -22 after reboot when i user dmesg | grep to search gpio. I don't know if I have made some mistake) /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h6"; /* * This fragment is needed only for the internal pull-up activation, * external pull-up resistor is highly recommended if using long wires */ fragment@0 { target = <&r_pio>; __overlay__ { gpio_key_wakeup: gpio_key_wakeup { pins = "PL8"; function = "gpio_in"; bias-pull-up; }; }; }; fragment@1 { target-path = "/"; __overlay__ { gpio-keys-user { /* * Use "gpio-keys" for EINT capable pins, "gpio-keys-polled" for other pins * add "poll-interval" property if using "gpio-keys-polled" */ compatible = "gpio-keys"; pinctrl-names = "default"; pinctrl-0 = <&gpio_key_wakeup>; key_wakeup{ label = "GPIO KEY_WAKEUP"; linux,code = <143>; /* KEY_WAKEUP, see include/uapi/linux/input-event-codes.h */ gpios = <&r_pio 0 8 1>; /* PA10 GPIO_ACTIVE_LOW */ }; }; }; }; }; The error message is : opi@orangepi3:~$ dmesg | grep -i gpio [ 2.642632] sun50i-h6-r-pinctrl 7022000.pinctrl: pin PL8 already requested by gpio-keys-user; cannot claim for 7022000.pinctrl:360 [ 2.642646] gpio-keys gpio-keys-user: failed to get gpio: -22 [ 2.642662] gpio-keys: probe of gpio-keys-user failed with error -22 [ 3.343678] sunxi-mmc 4020000.mmc: Got CD GPIO 3、armbian describe we can use "armbian-add-ovelay" to add a custom dts to /boot/user_overlays. But if my dts file have some error if I can delete the relative file directly ? Or I need use other command? (armbian-add-overlay is unavailable for H6 chip. We need to use dtc compile dts file to dtbo and then move it to /boot/overlay-user) 4、add the right ovelay to user-overlays line in /boot/armbianEnv.txt I know it is a old question. But I am so sorry as a newbie can not draw s whole picture about how to use gpio-keys and device tree. Anybody can give me some instructions? Thanks so much!
