evadim
Contact Methods
  • XMPP/Jabber
    evadim@evadim.ru
  • Github
    evadim
  1. Is there way to disable SPI flashing after u-boot upgrade?
  2. Spent a few days trying various combinations with Rockpi4c and Armbian 23.05.1 Bookworm with Linux 6.1.30-rockchip64 to get it working. Bootoader in SPI just hang at early start: U-Boot TPL 2022.07-armbian (May 27 2023 - 19:29:37) Few times I saw something like "DRAM init failed -19". Guide to flash SPI on Radxa Wiki completely changed to rkdeveloptool and maskrom mode. After a while I found which image nand-sata-install uses and flash via rkdeveloptool /usr/lib/linux-u-boot-current-rockpi-4c_23.05.1_arm64/rkspi_loader.img instead of Radxa uboot spi img. Works from first try! In boot console I see this warning: Loading Environment from SPIFlash... SF: Detected XT25F32B with page size 256 Bytes, erase size 4 KiB, total 4 MiB *** Warning - bad CRC, using default environment Not sure what changed. I hope this helps someone. SSD is cheap (but with DRAM onboard) A-Data XPG SX6000LNP Lite 128Gb
