Hello !
I recently reimaged my BPi M1 with the vanilla headless Debian Jessie from Armbian. But I have two problems:
Main problem (the worst): I have a RAID SATA to USB enclosure (this one: BS-EHD-35/DUALB). After some times and randomly, the drives stops spinning and the enclosure stops itself. I've disabled any power management on hard drive, setup a cron job to write a file every 5 min, disabled autosuspend in usb core...
I didn't have this problem with the legacy kernel. I cannot downgrade to it, because I'm using BTRFS with some non-compatible extensions. Note: this is a server with apache, Deluge, Plex and Sonarr.
Side problems (I can live with if the first is OK): Also, if the drive isn't connected, the BPi won't boot, and after the enclosure stops, the BPi hang and need a force reset to remount the drive and restart services. Tried a udev rule to automate it, but no luck.
Don't understand why the enclosure stops itself, it's not really documented, and tried everything I could think.
Thank you,
Arno
