I'm using vanilla Ubuntu Xenial 16.04 from http://www.armbian.com/lamobo-r1/
When I follow the forum posts for copying everything to the SATA drive and updating /etc/fstab and /boot/boot.cmd the system boots as expected to the SATA drive.
The problem I have is I get prompted to upgrade it on boot using apt-get upgrade. This also upgrades the kernel version from 4.6.2 to 4.6.3.
Because I have moved the system from the SD card to the SATA drive the new kernel doesn't load, only the old kernel with missing modules which causes problems.
When the kernel updates it updates the SATA drive /boot directory but the device uses the sd card /boot directory so things get screwed up.
I followed and read all the forum posts I could find on booting from the SATA drive and couldn't any reference to this so I'm not sure I missed something.
Anyway my solution was to remove the /boot directory from the SATA drive and symlink it from the /boot directory on the SD card and it all appears to work and the new kernel now shows up when I run uname -r . The correct modules now load with the updated kernel too.
Get the drive assignments
fdisk -l
Change below to match drives
SDCARD='mmcblk0p1'
SATA='sda1'
Create the temp directories
mkdir /tmp/1 /tmp/target
mount /dev/$SDCARD /tmp/1
mount /dev/$SATA /tmp/target
Modify the fstab and bootcmd files to match
sed -i -e "s/$SDCARD/$SATA/g" /tmp/1/etc/fstab
sed -i -e "s/$SDCARD/$SATA/g" /tmp/1/boot/boot.cmd
mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr
Set the sdcard to auto mount in /tmp/boot
echo "/dev/$SDCARD /tmp/boot/ ext4 defaults 0 1" >> /tmp/1/etc/fstab
Copy all the files across to the sata drive
(cd /tmp/1; tar --backup -c *) |tar -C /tmp/target -xv
Remove the boot directory from the sata drive and symlink it to the sdcard boot directory
rm -Rf /tmp/target/boot
ln -s /tmp/boot/boot/ /tmp/target/boot
sync
Then reboot
reboot
