asasl
  1. Allwinner_H3_Datasheet_V1.2.pdf up to five UART controllers In sun8i-h3-orangepi-pc.dts only 4 How do I use all five? serial@1c28000 { compatible = "snps,dw-apb-uart"; reg = < 0x1c28000 0x400 >; interrupts = < 0x00 0x00 0x04 >; reg-shift = < 0x02 >; reg-io-width = < 0x04 >; clocks = < 0x03 0x3e >; resets = < 0x03 0x31 >; dmas = < 0x15 0x06 0x15 0x06 >; dma-names = "rx\0tx"; status = "okay"; pinctrl-names = "default"; pinctrl-0 = < 0x19 >; phandle = < 0x64 >; }; serial@1c28400 { compatible = "snps,dw-apb-uart"; reg = < 0x1c28400 0x400 >; interrupts = < 0x00 0x01 0x04 >; reg-shift = < 0x02 >; reg-io-width = < 0x04 >; clocks = < 0x03 0x3f >; resets = < 0x03 0x32 >; dmas = < 0x15 0x07 0x15 0x07 >; dma-names = "rx\0tx"; status = "disabled"; pinctrl-names = "default"; pinctrl-0 = < 0x1a >; phandle = < 0x65 >; }; serial@1c28800 { compatible = "snps,dw-apb-uart"; reg = < 0x1c28800 0x400 >; interrupts = < 0x00 0x02 0x04 >; reg-shift = < 0x02 >; reg-io-width = < 0x04 >; clocks = < 0x03 0x40 >; resets = < 0x03 0x33 >; dmas = < 0x15 0x08 0x15 0x08 >; dma-names = "rx\0tx"; status = "disabled"; pinctrl-names = "default"; pinctrl-0 = < 0x1b >; phandle = < 0x66 >; }; serial@1c28c00 { compatible = "snps,dw-apb-uart"; reg = < 0x1c28c00 0x400 >; interrupts = < 0x00 0x03 0x04 >; reg-shift = < 0x02 >; reg-io-width = < 0x04 >; clocks = < 0x03 0x41 >; resets = < 0x03 0x34 >; dmas = < 0x15 0x09 0x15 0x09 >; dma-names = "rx\0tx"; status = "disabled"; pinctrl-names = "default"; pinctrl-0 = < 0x1c >; phandle = < 0x67 >; };
  2. Hello! Can I host Linux Armbian on the internal eMMC flash? It is also much faster CF cards.
