NotAnExpert
  1. Last night we lost power to the whole house, I had to manually start the NAS and when I tried to access my data there was nothing but empty shares. After checking OpenMediaVault Web UI and checking around, the file system status shows as "missing" and there is nothing under RAID Management and all the disks show properly under Storage > Disks. The NAS is set up as a Raid 6 on ext4 with five 12 TB drives. For starters, I wonder why the internal battery did not graciously shut down Helios64 as to avoid this from happening given that power outages are a rather common issue. Then, how do I get my file system back? After browsing some forums I noticed this info may seem important: lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT sda 8:0 0 10.9T 0 disk sdb 8:16 0 10.9T 0 disk sdc 8:32 0 10.9T 0 disk sdd 8:48 0 10.9T 0 disk sde 8:64 0 10.9T 0 disk mmcblk1 179:0 0 14.6G 0 disk └─mmcblk1p1 179:1 0 14.4G 0 part / mmcblk1boot0 179:32 0 4M 1 disk mmcblk1boot1 179:64 0 4M 1 disk cat /etc/fstab UUID=dabb3dbf-8631-4051-a032-c0b97eb285bd / ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro 0 1 tmpfs /tmp tmpfs defaults,nosuid 0 0 # >>> [openmediavault] /dev/disk/by-label/data /srv/dev-disk-by-label-data ext4 defaults,nofail,user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,acl0 2 # <<< [openmediavault] cat /etc/mdadm/mdadm.conf # This file is auto-generated by openmediavault (https://www.openmediavault.org) # WARNING: Do not edit this file, your changes will get lost. # mdadm.conf # # Please refer to mdadm.conf(5) for information about this file. # # by default, scan all partitions (/proc/partitions) for MD superblocks. # alternatively, specify devices to scan, using wildcards if desired. # Note, if no DEVICE line is present, then "DEVICE partitions" is assumed. # To avoid the auto-assembly of RAID devices a pattern that CAN'T match is # used if no RAID devices are configured. DEVICE partitions # auto-create devices with Debian standard permissions CREATE owner=root group=disk mode=0660 auto=yes # automatically tag new arrays as belonging to the local system HOMEHOST <system> # instruct the monitoring daemon where to send mail alerts # definitions of existing MD arrays ARRAY /dev/md/helios64:0 metadata=1.2 name=helios64:0 UUID=f2188013:e3cdc6dd:c8a55f0d:d0e9c602 cat /proc/mdstat Personalities : [linear] [multipath] [raid0] [raid1] [raid6] [raid5] [raid4] [raid10] md0 : inactive sde[4](S) sdc[2](S) sda[0](S) sdd[3](S) sdb[1](S) 58593766400 blocks super 1.2 unused devices: <none> fsck /dev/disk/by-label/ fsck from util-linux 2.33.1 e2fsck 1.44.5 (15-Dec-2018) fsck.ext2: No such file or directory while trying to open /dev/disk/by-label/ Possibly non-existent device? I don't want to lose data even if I have it backed up so I don't want to try to fix it blindly. And given that this could happen again to others and myself it would be very helpful to find a recovery method that others could use.
