mkultra
35 -
USB error after kernel update on ODROID-HC4
mkultra replied to Sergius's topic in Software, Applications, Userspace
I'm running this and it sees a USB stick fine : Armbian Community v25.5 rolling for RK3318 Box running Armbian Linux 6.14.0-rc4-edge-rockchip64 -
hi folks I've installed the pi-hole version that you guys have kindly delivered through the extra software I can't make it work with the default docker 'virtual network' how can I change it so that docker uses the host network?? I worked out that pi-hole is started using a start.sh but I looked at it and it's double dutch to me! cheers
hi, had to reflash one of my boxes.... did an update so on latest v24.11 rolling but I get an error in armbian-config when I go to set a static ip "/usr/lib/armbian-config/functions-network.sh: line 229: route: command not found" and I'm missing /etc/network/interfaces.........just an interfaces.out file that is 'not a file' apparently lol how do I change to a static IP? cheers
why do you need openwrt? surely just setting your DNS to your pi-hole/adguard 'filter' gives you the same result?
ok got it working by plugging the SD card into one of my 'already working' boxes initially, letting it resize the partition, then back to the PC to copy the image onto........bizarre right got too many boxes now....x3....lol.....I found they are really good for running adguard dns in a docker container...... anyone else running any interesting/docker stuff? cheers
hi folks, any idea why the MULTITOOL partition on SD keeps getting 'corrupted'? ie I can boot the TV box, the partition gets resized but then becomes 'inaccessible'.......error 'failed to mount' when plugged back into PC I've used this procedure fine before but bagged another cheapo box.....this problem is doing my nut in lol...tried different PC, different card......
you monitoring for chemtrails or what there? that's quite a selection you got going, good luck!
here you go https://termbin.com/55zf
hi folks, I've ended up with a difference of opinion with my 2 boxes somehow lol how do I change from 'untested automated build' to 'community creations' and vice versa? tried armbian-config and it doesn't seem to do anything....cheers Exhibits: BOX1 - this is an RK3318 Welcome to Armbian 23.11.0-trunk.41 Bookworm with Linux 6.5.2-edge-rockchip64 No end-user support: untested automated build BOX2 - this is an RK3328 - a H96 Max+ Welcome to Armbian 23.8.1 Bookworm with Linux 6.4.13-edge-rockchip64 No end-user support: community creations
ok so I played with my RK3318 box yesterday... first I switched to 'beta repository' in armbian-config and ended up with 6.4.13-edge-rockchip64 then I updated to bookworm.....all good today I changed the sources.list.d as I noticed docker was still pointing at bullseye after an update I ended up with: Welcome to Armbian 23.11.0-trunk.15 Bullseye with Linux 6.1.51-current-rockchip64 it was on trunk.7 yesterday but can't recall if that said Bullseye or Bookworm, doh I went back into armbian-config, changed to stable build, back to beta build but it's still on 6.1.51 any way to get back to 6.4.13? not urgent, it's more for learning as much as anything else thanks EDIT: update next day.....back to working, must have been a glitch in the matrix Welcome to Armbian 23.11.0-trunk.18 Bookworm with Linux 6.4.14-edge-rockchip64
hmmmm, CPU usage is always <= 100%........basic maths bruv
oh no! how can I update to the latest kernel? I looked here but no mention of rockchip https://github.com/armbian/community I've got a fast arch PC so can I compile my own kernel using that? thanks! PS oh yeah, how do I change motd? I've got a 3328 (as well as a 3318)
i must have been bored cos I decided to update to bookworm which worked ok but somehow I ended up going from kernel 6.1.11 to 5.15.93 after I did an 'unhold'
