HoSe_Colonia
  1. Confirmed: Armbian 21.02.0-trunk Focal with Linux 5.9.16-rockchip64 The one in the middle works: [ 922.891909] usb 6-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd [ 922.913139] usb 6-1: New USB device found, idVendor=090c, idProduct=2000, bcdDevice=11.00 [ 922.913162] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 922.913178] usb 6-1: Product: Intenso Flash Line [ 922.913193] usb 6-1: Manufacturer: SMI Corporation [ 922.915257] usb-storage 6-1:1.0: USB Mass Storage device detected [ 922.917468] scsi host0: usb-storage 6-1:1.0 [ 922.969173] usbcore: registered new interface driver uas [ 924.022772] scsi 0:0:0:0: Direct-Access Intenso Flash Line 1100 PQ: 0 ANSI: 6 [ 924.024647] sd 0:0:0:0: [sda] 245760000 512-byte logical blocks: (126 GB/117 GiB) [ 924.025007] sd 0:0:0:0: [sda] Write Protect is off [ 924.025029] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00 [ 924.025382] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 924.033101] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 924.058523] sda: sda1 sda2 sda3 [ 924.060440] sd 0:0:0:0: [sda] Attached SCSI removable disk The left one (corner) does not: [ 463.509617] usb 6-1: USB disconnect, device number 2 [ 463.515097] sd 0:0:0:0: [sda] Synchronizing SCSI cache [ 463.515366] sd 0:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=0x01 driverbyte=0x00
  2. Nanopi R4S with Armbian nightly build (21.02.0-trunk), my own build without any changes of the configs: http://ix.io/2KKP OpenSSL 1.1.1f, built on 31 Mar 2020 type 16 bytes 64 bytes 256 bytes 1024 bytes 8192 bytes 16384 bytes aes-128-cbc 118362.99k 356091.88k 700289.11k 949098.15k 1058919.77k 1064566.78k aes-128-cbc 346525.56k 796991.72k 1156316.59k 1282400.60k 1348845.57k 1351647.23k aes-192-cbc 113063.16k 318472.23k 573401.43k 732813.31k 797354.67k 801674.58k aes-192-cbc 330636.27k 727768.81k 987592.02k 1138004.65k 1190903.81k 1193454.25k aes-256-cbc 109763.73k 293123.05k 497607.94k 613483.52k 657989.63k 656288.43k aes-256-cbc 319682.34k 665284.33k 904484.52k 980995.41k 1021831.85k 1024671.74k 7ZIP: Total: 6546,6603,6576 cpuminer: Total Scores: 10.52,10.51,10.50,10.49,10.48,10.43 No big surprises No case, small fan, no heatsink.
