Seth
  1. oh thats why i never encountered the ch341/ch340 error, i started with the cli/minimal install
  2. please post output of the following commands while the printer is plugged in the usb and is turned on. ls /dev/tty* and lsusb i never had problems with usb serial communication with armbian before. please check your klipper make menuconfig settings and that it is exactly what is intended for your printer mainboard. here is the guide for your printer.
  3. open nvram_2734с.txt copy and paste all the contents and in the loaded config. bcmfmac4330* or brcmfmac4334* in /lib/firmware you can install klipper with kiauh just fine with this build of armbian i've been using it for 3 years now. you just need git installed and clone kiauh repository for a very convenient klipper install.
  4. thanks, will try it out and upload serial logs after i solder the wires on it. got a bit distracted since i'm currently cleaning up the other box from junk and trying to reflash and reinstall pihole.
  5. links on first post.
  6. hello, i got a new rk3328/3318 box and it is an MX10 box. board is MXQ-RK3328-D4_A ver: 2.0 date:20181219. i was wondering if anyone has the same board as mine and got armbian running on it. here are pics of the board. https://photos.app.goo.gl/ikSCNH7s59f2v5EE7 if serial logs are needed i can solder some wires to gather the info. thanks.
  7. works like a dream @jock. here's my freshly installed/updated hk1 max box dmesg using latest libreelec hdmi patched 6.3.13 kernel. i hope mainline gets around to updating hdmi timing stuff. brcm 6334 2.4G and 5G works out of the box. using it currently as pi hole box. for those having problems with rtl 2734c (rtl8237cs). wireless module that gets detected but cannot connect to AP, here's a reuploaded nvram you can try out (no guarantees though), it solved my problem way back with the rounded h96 max i am using as klipper host. file is not mine, credits to the original uploader. dmesg.log nvram_2734c.txt
