dwinz
Content Count
9 -
About dwinz
Rank
Newbie
Linux headers for rockchip64
dwinz replied to dwinz's topic in Common issues / peer to peer technical support
Yes rebooted after the upodate/upograde, made sure it was in "attached to beta repository", my only choices to download the source are 5.10.6 -9 and 5.9.16 -
Seriously confused now so tried to start from the beginning..... new sd... booted, update. upgrade, Armbian_config to the non-stable version (even have the red screen background) then did the download of headers and source... the result; uname -a Linux rockpro64 5.10.17-rockchip64 #trunk.125 SMP PREEMPT Wed Feb 17 12:29:35 UTC 2021 aarch64 aarch64 aarch64 GNU/Linux Then when I do Armbian_config I show only the source for 5.10.6 -
So why don't the stock methods work? Why should I go to the supposedly "unstable" version? -
Not sure of how to get to "nightly" builds as not a option that I find? -
You changed the title to headers but really trying to use the Armbian_config tool to load the source for the running version.... Trying to port things over to this version and specifically trying to get the gpiod stuff and spidev working and easier to just look and see if I have the source for what is running. gpiod was just easy and simply an apt away and spi was twiddling with the dtb/dts file and etc. to get the devices.... but to write drivers and etc. need the source. Used Armbian_config on other versions and it just downloads and installs the source. -
apt update && apt upgrade -y && apt install linux-headers-current-rockchip64 Hit:2 http://ports.ubuntu.com focal InRelease Hit:3 http://ports.ubuntu.com focal-security InRelease Hit:4 http://ports.ubuntu.com focal-updates InRelease Hit:5 http://ports.ubuntu.com focal-backports InRelease Hit:1 https://minio.k-space.ee/armbian/apt focal InRelease Reading package lists... Done Building dependency tree Reading state information... Done All packages are up to date. Reading package lists... Done -
Had done it previously but again... apt install linux-headers-current-rockchip64 Reading package lists... Done Building dependency tree Reading state information... Done linux-headers-current-rockchip64 is already the newest version (21.02.2). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. And again the other; apt update && apt upgrade -y && linux-headers-current-rockchip64 Hit:2 http://ports.ubuntu.com focal InRelease Get:3 http://ports.ubuntu.com focal-security InRelease [109 kB] Get:4 http://ports.ubu -
root@rockpro64-sys1:/home/dwinz# apt update && apt upgrade -y && linux-headers-current-rockchip64 Hit:2 http://ports.ubuntu.com focal InRelease Hit:3 http://ports.ubuntu.com focal-security InRelease Hit:4 http://ports.ubuntu.com focal-updates InRelease Hit:5 http://ports.ubuntu.com focal-backports InRelease Hit:1 https://minio.k-space.ee/armbian/apt focal InRelease Reading package lists... Done Building dependency tree Reading state information... Done All packages are up to date. Reading package lists... Done Buil -
In the newest image "Armbian_21.02.1_Rockpro64_focal_current_5.10.12_desktop.img" I downloaded the "Armbian config" the Source download choice box does not have the version "5.10.12" as a choice. The "headers" option does download the proper version. How do I get the source for it?
