Hi
I am using an OrangePi Zero 2+ with AllWinner H3 and i need both uart. I enable them with armbian-config and on pins
Uart2 on pins 8 and 10 work fine bat uart1 on pins 11, 13 don't.
The pin on this board is not the same as orangepi zero?
I mast make some setup to make uart1 to work?
auto@orangepizeroplus2-h3:~$ uname -a
Linux orangepizeroplus2-h3 5.9.14-sunxi #20.11.3 SMP Fri Dec 11 20:31:12 CET 2020 armv7l armv7l armv7l GNU/Linux
auto@orangepizeroplus2-h3:~$ cat /boot/armbianEnv.txt
verbosity=1
bootlogo=false
console=both
disp_mode=1920x1080p60
overlay_prefix=sun8i-h3
overlays=i2c1 uart1 uart2 uart3 usbhost2 usbhost3
rootdev=UUID=f2961b16-88cc-46d0-8297-931c6211f21c
rootfstype=ext4
usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
auto@orangepizeroplus2-h3:~$ ls -al /dev/ttyS*
crw--w---- 1 root tty 4, 64 Feb 26 07:57 /dev/ttyS0
crw-rw---- 1 root dialout 4, 65 Feb 26 07:58 /dev/ttyS1
crw-rw---- 1 root dialout 4, 66 Feb 26 07:58 /dev/ttyS2
crw-rw---- 1 root dialout 4, 67 Feb 26 07:56 /dev/ttyS3
crw-rw---- 1 root dialout 4, 68 Feb 26 07:56 /dev/ttyS4
crw-rw---- 1 root dialout 4, 69 Feb 26 07:56 /dev/ttyS5
crw-rw---- 1 root dialout 4, 70 Feb 26 07:56 /dev/ttyS6
crw-rw---- 1 root dialout 4, 71 Feb 26 07:56 /dev/ttyS7
auto@orangepizeroplus2-h3:~$ dmesg | grep tty
[ 0.000000] Kernel command line: root=UUID=f2961b16-88cc-46d0-8297-931c6211f21c rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 consoleblank=0 loglevel=1 ubootpart= ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
[ 0.000272] printk: console [tty1] enabled
[ 2.333990] printk: console [ttyS0] disabled
[ 2.334080] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 40, base_baud = 1500000) is a 16550A
[ 2.334160] printk: console [ttyS0] enabled
[ 2.335312] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 41, base_baud = 1500000) is a 16550A
[ 2.336286] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 42, base_baud = 1500000) is a 16550A
[ 2.337239] 1c28c00.serial: ttyS3 at MMIO 0x1c28c00 (irq = 43, base_baud = 1500000) is a 16550A
[ 4.955994] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 5.613942] systemd[1]: Found device /dev/ttyGS0.
[ 6.438922] systemd[1]: Found device /dev/ttyS0.
auto@orangepizeroplus2-h3:~$ pyserial-miniterm /dev/ttyS2
--- Miniterm on /dev/ttyS2 9600,8,N,1 ---
--- Quit: Ctrl+] | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H ---
sdfsdf
--- exit ---
