hive
  1. hive
    NanoPi R4S
    I built my own Armbian image from trunk (Armbian_21.05.0-trunk_Nanopi-r4s_focal_current_5.10.24.img) and it seems to work correctly. It does not have the issues that I experienced using the pre-built image.
  2. For anyone else trying to get the NanoPi R4S working, I built my own Armbian image from trunk (Armbian_21.05.0-trunk_Nanopi-r4s_focal_current_5.10.24.img) and it seems to work correctly. It does not have the issues that I experienced using the pre-built image.
  3. Hi @mathieuh and @sfx2000 I am running into the same inconsistent bringup of the network interfaces that @mathieuh mentioned in this Armbian Development > Bring Up thread: https://forum.armbian.com/topic/15932-nanopi-r4s/ Did either of you come up with a resolution and/or have any tips to get consistent initializations of the network interfaces on startup of the R4S? I'd appreciate any tips or even pointers in the right direction. Cheers!
  4. I'd like some help please. The ethernet device naming seems inconsistent and sometimes changes following reboots. Sometimes one interface comes up as eth0 and sometimes as eth1, and sometimes not at all. The enp1s0 interface seems to reliably come up, but not with the right config (sometimes it uses the config for enp1s0 and sometimes for eth0). I am trying to assign status IP addresses (on different networks) to each interface, but because of the unreliable bringup of the network interfaces, I can't get a config that starts up correctly and consistency on reboots or cold boots. As a test I ran the friendly-core-lite-focal from FriendlyCore and it does not have this issue. Is there something I need to do on armbian to get the network interface bringup to work? I have static IP configs in /etc/network/interfaces.d called eth0, eth1 (these are the same, call it network A, because the 2nd network seems to sometimes come up as eth0) , and enp1s0 (configured for my second network, call it network I'd greatly appreciate any help in making the network bring up consistent and reliable.
  5. Sorry my mistake. I thought I was posting in the community forum first, to see if anyone has already run into this. I was not ready to file I bug--I just posted in the wrong place.
  6. I'd like some help please. The ethernet device naming seems inconsistent. Sometimes one interface comes up as eth0 and sometimes as eth1, and sometimes not at all. The enp1s0 interface seems to reliably come up, but not with the right config (sometimes it uses the config for enp1s0 and sometimes for eth0). I am trying to assign status IP addresses (on different networks) to each interface, but because of the unreliable bringup of the network interfaces, I can't get a config that starts up correctly and consistency on reboots or cold boots. As a test I ran the friendly-core-lite-focal from FriendlyCore and it does not have this issue. Is there something I need to do on Arabian to get the network interface bringup to work? I have static IP configs in /etc/network/interfaces.d called eth0, eth1 (these are the same, call it network A, because the 2nd network seems to sometimes come up as eth0) , and enp1s0 (configured for my second network, call it network I'd greatly appreciate any help in making the network bring up consistent.
  7. hive
    NanoPi R4S
    I'm running into the issue that @mathieuh described where enp1s0 comes up and the other interface either doesn't come up or shows up seemingly randomly as eth0 or eth1 @mathieuhDid you ever find a fix for this? @sfx2000 Do you have any pointers on u-boot and device tree optimization to resolve this? Armbian on this board seems unreliable without resolving the network bringup consistency--What recommendations do people have to resolve this?
