jsr
  1. I'm on Armbian 21.08.2 Buster with Linux 5.10.60-mvebu and CESA is not functional. Regards, James
  2. Hi @djurny, here you go: cryptsetup benchmark: # Tests are approximate using memory only (no storage IO). PBKDF2-sha1 258524 iterations per second for 256-bit key PBKDF2-sha256 364595 iterations per second for 256-bit key PBKDF2-sha512 179550 iterations per second for 256-bit key PBKDF2-ripemd160 191345 iterations per second for 256-bit key PBKDF2-whirlpool 28370 iterations per second for 256-bit key argon2i 4 iterations, 71599 memory, 4 parallel threads (CPUs) for 256-bit key (requested 2000 ms time) argon2id 4 iterations, 73566 memory, 4 parallel threads (CPUs) for 256-bit key (requested 2000 ms time) # Algorithm | Key | Encryption | Decryption aes-cbc 128b 95.1 MiB/s 98.1 MiB/s serpent-cbc 128b 27.6 MiB/s 30.7 MiB/s twofish-cbc 128b 40.3 MiB/s 45.4 MiB/s aes-cbc 256b 90.7 MiB/s 93.1 MiB/s serpent-cbc 256b 28.0 MiB/s 31.3 MiB/s twofish-cbc 256b 41.2 MiB/s 46.2 MiB/s aes-xts 256b 62.7 MiB/s 54.9 MiB/s serpent-xts 256b 29.7 MiB/s 31.1 MiB/s twofish-xts 256b 44.0 MiB/s 45.7 MiB/s aes-xts 512b 47.7 MiB/s 41.5 MiB/s serpent-xts 512b 29.8 MiB/s 31.1 MiB/s twofish-xts 512b 44.0 MiB/s 45.7 MiB/s interesting, I do see CESA interrupts count up from the cryptsetup benchmark: 48: 24618 0 GIC-0 51 Level f1090000.crypto 49: 0 0 GIC-0 52 Level f1090000.crypto syslog: https://pastebin.com/AacFP5R8 Thanks!
  3. @djurny, I have a /proc/crypto (but not /proc/cryptinfo), link at the bottom. Apologies, I should have explained using the mmc device: that was used just to confirm the issue still existed when starting afresh using matzman666's instructions. I had some spare space available on that mmc device, and when using it I was only checking the CESA interrupt count in /proc/interrupts. My real storage is a pair of hard drives that each can read sequentially at ~180 MB/s (tested with dd). uname -a: Linux helios4 5.10.21-mvebu #21.02.3 SMP Mon Mar 8 00:59:48 UTC 2021 armv7l GNU/Linux /proc/crypto: https://pastebin.com/QuSpD5u5
  4. Hi there! I have been using LUKS2 encrypted disks on my helios4, and I've noticed that the encryption/decryption is no longer making use of the CESA accelerator. I don't see the relevant interrupts counting up: 48: 0 0 GIC-0 51 Level f1090000.crypto 49: 0 0 GIC-0 52 Level f1090000.crypto and my decryption speed is a lot lower (~45 MB/s) than it used to be (~100 MB/s). This used to be working on this OS install (Ambian Debian stretch, apt dist-upgrade'd to buster 21.02.3), and I wonder if there may have been a regression somewhere along the line. I've also tested using matzman666's examples above for setting up a LUKS2 encrypted disk, and I still have the same issue: I don't see any CESA HW acceleration with LUKS2. I checked and I do have the marvell_cesa module loaded. Here is the cryptsetup command: cryptsetup -s 256 -c aes-cbc-essiv:sha256 --sector-size 4096 --type luks2 luksFormat /dev/mmcblk0p2 I have also tried a fresh install of the latest Armbian Debian buster 21.02.3 and Armbian Ubuntu focal 21.02.3, and I still have no CESA acceleration. Has anyone seen this issue? How do we get LUKS2 to use the CESA hardware these days? Regards, James
