Willena
  1. After having spent a lot of time searching for the solution, I finally found it. UART1 is not enabled by default. But referenced in the device-tree. It was as simple as changing some option in the dts. After figuring out the symbol of UART1 in the symbol section of the dts __symbols__ { ... uart0 = "/serial@ff110000"; uart1 = "/serial@ff120000"; uart2 = "/serial@ff130000"; ... Further in the file we can find more information on the definition of uart1 (also known with symnol serial@ff120000) serial@ff120000 { compatible = "rockchip,rk3328-uart\0snps,dw-apb-uart"; reg = < 0x00 0xff120000 0x00 0x100 >; interrupts = < 0x00 0x38 0x04 >; clocks = < 0x02 0x27 0x02 0xd3 >; clock-names = "baudclk\0apb_pclk"; dmas = < 0x12 0x04 0x12 0x05 >; dma-names = "tx\0rx"; pinctrl-names = "default"; pinctrl-0 = < 0x25 0x26 0x27 >; reg-io-width = < 0x04 >; reg-shift = < 0x02 >; status = "disabled"; phandle = < 0x85 >; }; Notice the disabled value in the status field. Changing the status from 'disabled' to 'okay' did the trick. After a restart UART1 was available on /dev/ttyS1 \0/
  2. Hello everyone. I'm using the latest version of armbian for the NanoPi R2S. I noticed that the board has 4 exposed GPIO ports on the board. I'm interested in using the RX1 and TX1 and use it for the UART interface. It seems I cannot use it. It might be disabled by default. Can somebody confirm or not if UART1 is enabled by default and if not what should I do to enable it ? Thanks Guillaume
