dennistsc
  1. thanks for your reply i'm using the following to change the mac address sudo vim /etc/rc.local sudo /sbin/ifconfig wlan0 down sudo /sbin/ifconfig wlan0 hw ether 00:AA:BB:CC:DD:EE sudo /sbin/ifconfig wlan0 up but my question is: is it have any way to check the firmware. "Armbian_5.77_Aml-s905_Ubuntu_bionic_default_5.0.2_20190401" to check which part of the firmware change the wifi mac address??
  2. i already found a way to change it but i want to try change the firmware. change the firmware keep the same mac address as before.
  3. problem with the wifi mac address are the same at all s905 tv box hi i have a problem about the mac address on the android box. i use 3 boxes and the wifi mac address are the same. 1. i'm using firmware "Armbian_5.77_Aml-s905_Ubuntu_bionic_default_5.0.2_20190401" - use the uEnv.ini to flash the ubuntu into the box. 2. the box CPU: Amlogic S905D, ARM Cortex-A53, Quad Core 2GHz WIFI/Bluetooth: CYW43455 (same as Raspberry Pi 3B+) 2.4G/5G WiFi IEEE 802.11n/ac with Integrated Bluetooth 4.1 could you let me know is it the firmware change the wifi mac address? if so, which part of the firmware will not change the mac address? thanks you
