Yaroslav Ogiy
  1. Strange, but after I tried to boot from SD (it was not bootable, as discovered), OPI works as expected
  2. Hello, problem is next: my Orange Pi 3 now can't get IP address from my router. To solve it, I've connected via USB-TTL and on step "login:" it totally stucks and doesn't response for keyboard. What variants do I have, except reinstall OS? :) U-Boot SPL 2020.10-armbian (Feb 04 2021 - 00:24:13 +0100) DRAM: 2048 MiB Trying to boot from MMC2 NOTICE: BL31: v2.2(debug):a04808c-dirty NOTICE: BL31: Built : 00:24:06, Feb 4 2021 NOTICE: BL31: Detected Allwinner H6 SoC (1728) NOTICE: BL31: Found U-Boot DTB at 0xc07e188, model: OrangePi 3 INFO: ARM GICv2 driver initialized NOTICE: PMIC: Probing AXP805 NOTICE: PMIC: AXP805 detected INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2020.10-armbian (Feb 04 2021 - 00:24:13 +0100) Allwinner Technology CPU: Allwinner H6 (SUN50I) Model: OrangePi 3 DRAM: 2 GiB MMC: mmc@4020000: 0, mmc@4022000: 1 Loading Environment from FAT... Unable to use mmc 1:1... In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: No ethernet found. starting USB... No working controllers found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc1(part 0) is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 3173 bytes read in 2 ms (1.5 MiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 203 bytes read in 1 ms (198.2 KiB/s) MMC: no card present 35737 bytes read in 6 ms (5.7 MiB/s) 4191 bytes read in 3 ms (1.3 MiB/s) Applying kernel provided DT fixup script (sun50i-h6-fixup.scr) ## Executing script at 45000000 10050849 bytes read in 1007 ms (9.5 MiB/s) 21792776 bytes read in 2181 ms (9.5 MiB/s) Moving Image from 0x40080000 to 0x40200000, end=41730000 ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 10050785 Bytes = 9.6 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 4966a000, end 49fffce1 ... OK Loading Device Tree to 00000000495f8000, end 0000000049669fff ... OK Starting kernel ... Armbian 21.02.3 Buster ttyS0 orangepi3 login:
