stronthoop
stronthoop's Achievements
  1. Hi SymbiosisSystem, i've had a similar situation and reinstalled everything just to find out it was the browser type I was using. Don't use Internet explorer, but Brave browser / google chrome. That should solve your issue. The SSH timeout is weird.. Maybe you check dmesg log for what happens at the last line before you rebooted. Just my 2 cents. Kr, Stront
  2. dmitri don first of all thanks so much sharing the third command this fixed my ZFS in OMV5!! sudo armbian-config Go to Software and install headers. nano /etc/apt/sources.list #add these lines to your file. #---------------------------------------------------------------------------------------------------- deb http://deb.debian.org/debian buster main contrib non-free #deb-src http://deb.debian.org/debian buster main contrib non-free #1deb http://deb.debian.org/debian buster-updates main contrib non-free #deb-src http://deb.debian.org/debian buster-updates main contrib non-free #2deb http://deb.debian.org/debian buster-backports main contrib non-free #deb-src http://deb.debian.org/debian buster-backports main contrib non-free #3deb http://security.debian.org/ buster/updates main contrib non-free #deb-src http://security.debian.org/ buster/updates main contrib non-free #---------------------------------------------------------------------------------------------------- #save //Install DKMS v2.0.1 sudo apt install zfs-dkms zfsutils-linux zfs-auto-snapshot //unhash #1,#2,#3 and save apt update && apt upgrade -y && apt dist-upgrade && apt install linux-headers-current-rockchip64 #+++++++++++++++++++++++++++++++++++++++++++++++++++++ //update headers manually - not necessary if above procedure worked. #https://imola.armbian.com/apt/pool/main/l/ wget https://imola.armbian.com/apt/pool/main/l/linux-5.10.35-rockchip64/linux-dtb-current-rockchip64_21.05.1_arm64.deb wget https://imola.armbian.com/apt/pool/main/l/linux-5.10.35-rockchip64/linux-headers-current-rockchip64_21.05.1_arm64.deb wget https://imola.armbian.com/apt/pool/main/l/linux-5.10.35-rockchip64/linux-image-current-rockchip64_21.05.1_arm64.deb dpkg -i linux-dtb-current-rockchip64_21.05.1_arm64.deb dpkg -i linux-headers-current-rockchip64_21.05.1_arm64.deb dpkg -i linux-image-current-rockchip64_21.05.1_arm64.deb sudo apt install zfs-dkms zfsutils-linux zfs-auto-snapshot #+++++++++++++++++++++++++++++++++++++++++++++++++++++ //install omv armbian-config -> Software -> Softy -> mouseclick omv to get * -> click install #+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ //optional not necessary if above went ok, this includes the extras now. //and after install also the extras as per the video above. https://wiki.omv-extras.org/ //commands: wget -O - https://github.com/OpenMediaVault-Plugin-Developers/packages/raw/master/install | bash #+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ connect to OMV localhost:80, change ssh / omv port to another port if you want for your reversed http tunnel in putty. (when you work remote) go to update management -> check -> update to latest version (5.6.7-1 usul) kernel 5.10.35-rockchip64 go to OMV-extras -> tick extra repos and back ports to green -> save updates -> run update, run omv-update, run upgrade, run dist-upgrade, run apt clean go to plugins -> scroll down and install openmediavault-zfs 5.0.6 Install all other plugins you need. (install luks after openmediavault-zfs, also encryptionspeed is 3,5 times faster than in zfs itself) root@helios64:~# sudo modprobe zfs root@helios64:~# lsmod | grep zfs zfs 3690496 6 zunicode 331776 1 zfs zzstd 389120 1 zfs zlua 151552 1 zfs zcommon 90112 1 zfs znvpair 98304 2 zfs,zcommon zavl 20480 1 zfs icp 253952 1 zfs spl 110592 6 zfs,icp,zzstd,znvpair,zcommon,zavl root@helios64:~# root@helios64:~# zfs version zfs-2.0.3-1~bpo10+1 zfs-kmod-2.0.1-1 root@helios64:~# I am not sure if you want OMV with it. My guess that your problem is kernel header related. Please let me know if this is a help to you Kr, Stront
