Vigo
  1. Hello First of all, thank you for the great effort of the Armbian project. In second place: I have a NanoPi Duo device, which has been working fine with an old version of Armbian. But when trying to use the latest version, it happens that the serial port console continuously gives the following message and does not allow login ... ... [ OK ] Started Update UTMP about System Runlevel Changes. [ OK ] Started Network Manager Script Dispatcher Service. nanopiduo login: root (automatic login) Authentication failure nanopiduo login: root (automatic login) Authentication failure nanopiduo login: root (automatic login) Authentication failure ... The nanopi duo only gives the possibility of access by UART, since in practice, the analog video output does not work. Does anyone have a solution for this problem? Thanks!
