timonoj
22 -
timonoj's Achievements
Ok. I am now considering to move to a more recent kernel. Searching linux-image I can see there's a linux-image-current-sunxi which should kick it to 5.12.12-sunxi edge, for which I believe there are headers. Is this kernel going to work with my banana pi M1? Anything I should be aware of? As mentioned, my main fear is the Banana not coming back online, for which I have very little way to fix it anytime soon, given the pandemic.
So...I'm trying to find the linux headers for my Banana Pi M1, so I can install Wireguard on it. But seems there's no sanxi headers? Also...no headers for that kernel whatsoever. The generic ones stop at 4.18 then jump to 5.0. Then there's a bunch of raspi and raspi2 headers, and then the misterious to me linux-headers-edge-sunxi 21.05.6, which I guess won't work on mine. Where should I get headers for my Banana Pi? Also just in case, I'm a bit worried about doing something too drastic, since this little thingy is located in another continent. Thanks!
Hi guys! I'd like to download the correct image for my Banana Pi M1, but I don't seem to be able to find it. I've been searching already for a bit without much luck. Is it supported? Am I missing something? Thanks!
Thanks Rodolfo. Yeah, I'd consider that as an option...or maybe even a tiny SSD. But I'd really like the way of complex now, way easier maintenance later. After all, I'm having these trouble due to having it very easy on the go setup before...that I now need to completely change. If I get the iSCSI going, I can get easy snapshots and backups on the go, plus some other benefits, like expandable storage anytime I want, without even rebooting the Banana. This Banana is/will be handling all my personal cloud (seafile), backups and some other tasks...I want it running with the less maintenance possible once it works. Ok, so this is a failure, but an encouraging one: It's really reaching my NAS, but at the wrong path. The NAS specifies a fie bananapi.scr, and the path should be tftp_root/bananapi. There's a tftp_root/pxelinux.cfg with a working default file that launches a menu for different x86/x64 distros (only a testing live ubuntu at the moment). Not sure why it goes to pxelinux.cfg path if I didn't ask it to. The SD's boot.cmd is: And then the more complete boot.cmd at the tftp_root/bananapi goes as follows: Now to be honest, I'm not sure if it got stuck at the SD's boot.cmd or it managed to reach the second one. I think it's the first. It then fails to get the IP, not sure why and goes to get dhcp anyway. It doesn't look too bad to start with. EDIT: Well it seems to reach the bananapi/bananapi.scr path, as that's the transfer seen at the top of the screen "17.6 KiB/s, Done". With a dhcp IP instead of the one I tried setting, so I guess that command is wrong. Then it fails with the misaligned operation, which I have no clue how to fix, and then goes rambling around trying to find any other script. Not sure why it doesn't stick to the bananapi.scr.
Ok...This is a bit over what I've done before so far. I found several guides more, like this one (for x86), and this other one, the most promising so far, for a Raspberry, using uboot and all. So far I dumped the working SD contents to the iSCSI target. And I have a working TFTP I can reconfigure in a minute to point somewhere else. However I'm a bit confused on editing the boot.cmd: My doubts here: How could I specify a fixed address in the uboot script instead of dhcp? As I want my banana to be a server, and I already have an IP for it. If the /etc/network/interfaces sets a different IP later on, I'm afraid I might get disconnected from the target. What's with this: What does the 0x43f0000 mean, and should I change it for our bananas? Should I compile the /boot/boot.cmd in the SD exactly on that path while running from the banana? If anything fails, I don't get a do-over since it will no longer boot, right? Thanks!
Hi guys! I'm embarking myself in a rather messy subject, as in, not very tested. I'd like to get rid as much as possible of the SD usage, and I don't want to use a local HDD either (wouldn't look neat where the Banana Pi sits). So...I'm trying an iSCSI target in a NAS! I'm trying to follow this guide, but I'm full of doubts. As the guide is designed for a normal computer, it reaches the point where it starts talking about GRUB. How do we perform boot on the Banana? Can anyone let me know where can I find documentation on the ARM boot process for armbian? Thanks!
Tutorial Docker on armbian!
timonoj replied to MathiasRenner's topic in Reviews, Tutorials, Hardware hacks
Hmm...You mean only for the docker containers? I can try to see if it takes a iSCSI partition as the mount point for /var/lib/docker...Worth a shot. Thanks! -
Yup, did that Unsupported by docker, and crashes. It didn't like it. Apparently NFS is not in their plans yet. EDID: Well apparently some dude managed to do it by modifying a bunch of things...here. https://whyistheinternetbroken.wordpress.com/2015/05/12/techusing-nfs-with-docker-where-does-it-fit-in/ I might have to try that path, but it doesn't look like a piece of cake. At least all the nfs shares and client and autofs mounts are already there... -
Sure...but not the container itself, which goes to the SD regardless what you might want. I tried linking the folder to a NAS mount, but it doesn't like that. -
Thanks, I might consider booting from PXE...Although that is way more complicated to setup I think, and messier to maintain. And the additional HDD...Sure that's an option, but I'd like to avoid having to purchase another HDD since I already have a NAS (hence my interest in iSCSI, the NAS sets those in almost just two clicks). -
At this moment zero, since I was doing a brand new install. During testing I tried a beta app that takes some 2.5GB on its own due to lack of dependencies polishing I think (Open365). Also Seafile deals with a huge amount of storage, but that one is happily taking a NFS mount point. Problem is, it's not very portable should I change the hardware or configuration on the OS (or OS completely, for that matter). I was thinking it to port it to a docker, but then again I'm facing the same trouble. Plus, any of these working on an SD would imply serious I/O whenever dealing with big chunks of files...I wouldn't trust it to keep the important data, just the system files. I'd prefer to even store the docker containers somewhere else. Safer. EDIT: Do you guys think it would be possible to mount EVERYTHING on a iSCSI target? Even the OS and boot from it? It would make snapshotting the whole OS a piece of cake. -
Hi guys, Given the not so great durability of SD cards (and limited storage...I try to keep everything on NFS mounts, but there's always some log that decides to randomly fill the SD card full of crap), and the incapability of run properly docker (it runs, but it NEEDS to use damn local storage, and won't take an NFS mount for some reason...it gets full real quick), I was considering to boot to a iSCSI target. This would let me expand storage anytime I need, plus it would make backup and snapshots a piece of cake. Is there a way to do this?
So...Is it included in the official images now? I just downloaded the Ubuntu image for Banana Pi, and I'm getting about 40Mbit speeds.
