filjoa
  1. Hi I don't know what I ended up doing but now I'm not able to install the home assistant due to problems with Docker Is it possible to re-install the image I have on the usb pen in this box, and make a clean instalation?
  2. Hi I have on TVBox X9T Pro https://www.amazon.co.uk/Bqeel-Android-Bluetooth-Amlogic-Output/dp/B078MHCTWT his instalation is correct: https://ibb.co/KwqHJKx
  3. hi thought the problem was on boot in armbian as HA process or Docker won't start with the installation USB pen it is possible to do a fresh installation of armbian? how can I do this?
  4. Hi I finally got a clean install of Armbian. What is the best procedure to install HA OS or Supervisor
  5. Hi I installed my HA system on an android box Amlogic S912 Octa core, with armbian, everything works fine until i restart the box. Box: https://www.amazon.co.uk/Bqeel-Android-Bluetooth-Amlogic-Output/dp/B078MHCTWT After restarting the box I can no longer access the HA, but I can access the box with putty. For everything to work again, I have to delete docker, HA and re-install everything again, but as soon as I remove the power, I am again without access by brower. I think the problem is in some service that is not on startup, but I have no experience with linux and I don’t know how to solve this problem Can anyone help me try to find the problem? Best Regards
