Dear all;
I'm looking for some help with my Helios64 NAS, since I update kernel to 5.15, zfs-dkms won't work.
Which is normal, since the most recent version available for Helios64 of zfs-dkms is 2.0.3-1~bpo10+1 (tested on 1st April 2022), and this version is only compatible with kernel from 3.10 to 5.10.
Then the first solution that I thought was to downgrade to 5.10 through the armbian-config tool, however when I'm trying to install the linux-headears (through armbian-config) I'm having the herdears of 5.15 (same issue with apt install linux-headers-current-rockchip64) while zfs-dkms looking for 5.10.
Preparing to unpack .../zfs-dkms_2.0.3-1~bpo10+1_all.deb ...
Unpacking zfs-dkms (2.0.3-1~bpo10+1) ...
Setting up zfs-dkms (2.0.3-1~bpo10+1) ...
Loading new zfs-2.0.3 DKMS files...
It is likely that 5.10.63-rockchip64 belongs to a chroot's host
Building for 5.15.25-rockchip64
Building initial module for 5.15.25-rockchip64
configure: error:
*** None of the expected "capability" interfaces were detected.
*** This may be because your kernel version is newer than what is
*** supported, or you are using a patched custom kernel with
*** incompatible modifications.
*** ZFS Version: zfs-2.0.3-1~bpo10+1
*** Compatible Kernels: 3.10 - 5.10
Error! Bad return status for module build on kernel: 5.15.25-rockchip64 (aarch64)
Consult /var/lib/dkms/zfs/2.0.3/build/make.log for more information.
/var/lib/dkms/zfs/2.0.3/build/make.log:
DKMS make.log for zfs-2.0.3 for kernel 5.15.25-rockchip64 (aarch64)
Fri 01 Apr 2022 05:38:22 PM UTC
make: *** No targets specified and no makefile found. Stop.
I try then to perform a fresh installation of the system by downloading Armbian_21.08.2_Helios64_buster_current_5.10.63, and then it goes worst since I can't download the header through armbian-config (nothing happen), and apt install linux-headers-current-rockchip64 keep installing the sources for 5.15 ('/usr/src/linux-headers-5.15.25-rockchip64').
So the problem how I see it is either to:
* Get the linux-headers of the previous kernel.
* obtaining a zfs-dkms version compatible with 5.15
Thank you in advance for your help.
PS: I am aware of the docker alternative, but I prefer to use zfs-dkms.
