n3o
127 -
@prahal I have tried from ssh "smartctl -d sat -i /dev/sdc" and "smartctl -d sat -i /dev/sdd", the first has take 50 seconds, the second has take 1 minute. However with -d sat option it's more faster than the week ago but run "smartctl -d sat -i /dev/sda" it's take just 1 seconds. It's normal that time or not?
hi, thakk You for the answer, but my old monitor have a DVI connection and not VGA connection... so the adapter that I have is from HDMI side box and dvi side monitor. adapter is DVI-D type, so side hardware doesn't to be compatibility issue. As written by @MattWestB seems that it's due to video mode, but I don't know if there is and how add this patch Hi, I was thinking that @jock and @fabiobassa doesn't know for the existing of your nand driver. If You don't want that is made an armbian image with your driver no problem.
Dear to all, I have a Helios64 unit with 2 hdd (both WD60EFRX). I have bought also an external enclousure UGREEN 5 Bay Hard Drive Enclosure ( https://eu.ugreen.com/collections/hard-drive-enclosures/products/ugreen-5-bay-hard-drive-enclosure-5-x-18tb-raid-array-hard-disk-docking-station ) and 2 WD140EDGZ and these 2 hdd are mounted inside UGREEN enclousure because I want format and test it (when all will work fine I'll exchange a WD60EFRX with a WD140EDGZ so the drives inside the enclousure will have a backup scope). The enclousure is powered by external adapter, the system image installed is the Armbian 22.02.1 with Linux kernel 5.15.93-rockchip 64 and openmediavault 6.6.0-2 (Shaitan). If I have the enclousure turned off and from open media vault access to smart drive section (storage -> S.M.A.R.T. -> device section), the smart information (related to the 2 WD60EFRX) are showed in about 4-5 seconds but if I turn on the enclousure with the 2 device WD140EDGZ , the smart drive section is showed after 4 minutes. Sometimes the section isn't showed but it's showed an error message "Http failure response for http://192.168.1.44/rpc.php: 504 Gateway Time-out". I'm sure that this problem occur also with the transfer of files (hoping that doesn't occur wrong data information transfer with damaged files also) and I have already googled for this issue on the web but I haven't found nothing that help me to solve the issue. I attach here the 2 dmesg output that I have take from 2 distinct session with putty dmesg of first session dmesg of second session my question is: the problem it's related from standard drivers inside the image, from the kernel or it's necessary take manufacturer driver source and compile it? How can I solve this issue? Hope that somebody help me Best regards
@all ilmich has told me that he have made a port driver of NAND in his libreelec build. The driver is available here https://github.com/ilmich/LibreELEC.tv/tree/libreelec-10.0/projects/Rockchip/devices/RK322x/patches/linux/default . If somebody is interested, he can try to make an image armbian with kernel 5.10. I have forgot another issue with armbian legacy image: the board doesn't work on my old monitor 1280*1024. The monitor plug was of dvi type and I have used an adapter hdmi-dvi... Can be this the cause?
@jock can You help me ? In the previous post You have already managed this contents
I have made some research and I have found this https://forum.pine64.org/showthread.php?tid=6373&pid=39867 , https://forum.odroid.com/viewtopic.php?t=44509 and https://github.com/rockchip-linux/mpp/tree/develop . Goal is: play bluray iso with vlc media player (both encrypted that not encrypted such this for example https://durian.blender.org/download/ and iso here https://download.blender.org/durian/movies/ ) so I have found this article https://www.omgubuntu.co.uk/2022/08/watch-bluray-discs-in-vlc-on-ubuntu-with-makemkv and I have reached this link https://forum.makemkv.com/forum/viewtopic.php?f=3&t=224 . So I think that I must uninstall current makemkv-bin, makemkv-oss and ffmpeg compiled with "./configure --prefix=/tmp/ffmpeg --enable-static --disable-shared --enable-pic --enable-libfdk-aac" first, and the recompile ffmpeg with "--enable-rkmpp". But how preciously? Moreover Can I install install_media script removing kodi section (also for earn some space considering that are available only 1.3 GB) for get rkmpp tool? I have compiled this build of ffmpeg https://packages.debian.org/bookworm/ffmpeg , it's a valid build or there is a ffmpeg modded rkmpp ? for vlc, I should modify association between h264 - h264 decoder of ffmpeg with h264 - h264_rkmpp decoder or should modify ffmpeg that it should consider h264 call as h264_rkmpp ? What are Armsoc driver, Libmali for Utgard Mali 400 (both X11 and GBM versions) and GL4ES OpenGL to OpenGL ES wrapper? I today have compiled RKMPP , why to compile ffmpeg I should specify also --enable-libx264 \ --enable-libx265 \ ? Aren't they already included in compile time?
ok, if a blu-ray is an h264 fullhd or 4k video why hardware should be good only for Youtube videos? However, if I install install_media it's necessary install also kodi ? little o.t.: It's possible know the script used to compile ffmpeg ? I ask this because for play blu-ray I should execute this steps https://forum.makemkv.com/forum/viewtopic.php?f=3&t=224 and should compile ffmpeg with ./configure --prefix=/tmp/ffmpeg --enable-static --disable-shared --enable-pic --enable-libfdk-aac . Can You tell me the tool to relearn ir remote control ?
I have tried to play a blu-ray image, but vlc is very slow and I have see only a frame with some squares. I think that isn't enabled hardware decoding. How can enable it? Can I ask here or I must open a thread ? I'm sure that mxq pro can play h264 stream full hd so the cause isn't a hardware limit
what tool? ok, I think that was easy so I can avoid to open another thread...
I have made trial setting 660 mhz as frequency ram but sometimes don't boot. So right value for the ram is set item default (that don't specifies the frequency value). Another doubt it's related to first voice (RK3228A vs RK3228B) ... I have set RK3228A with a low frequency but I don't know if RK3228B can be usable. Yesterday I have compiled MakeMKV and all works fine after more then 2 hours of working task. I have to ask only few question: 1. how configure ir remote control to turn on the device from ir and use the 4 arrows key as mouse? 2. I have a problem with file manager accessing a windows smb share: it ask necessary for a username while accessing the same windows share folder from android and other windows pc it works without asking nothing. Going in properties -> sharing there are 2 users: "Everyone" wirh "Read/Write" grant and "Utente" with "Owner" grant. Do You know how to fix it?
ok, but how do You have calculated that value? Because I have found ddr3-1600 mhz. Moreover, I have another doubt: can be possible that a lower frequency can made system instable? My basically knowledge about overclock was related to the fact that only higher frequency than standard can cause instability issue. However, I'll do just a last trial at 660, if system doesn't boot I'll set default.
thank you for the site, final code is different from that above. However I'm more confused: here https://www.arrow.com/en/products/mt41k512m4da-125m/micron-technology is written that is a ddr3-1600 Mhz. First of all 1600 Mhz value isn't present in rk322x-config tool, after this if setting ddr3-528 cause freeze at boot, how it's possible think to set 1600 Mhz? Moreover I don't have feedback even with size value: in that site is written 512 M x4, but why my ram memory is only 1 GB and not 2 GB (the 1GB value was present also with first old rom Android stock)
nothing can found, also removing -6:D string right value is MT29F128G08CECDBJ4-6ES:D
these?
for Ram what should search in my picture? for led I have set "led-conf2" R329q because in the board this is the value written for wifi ssv6051p I think it's ok Do You know how turn on device from ir remote control?
