Menos_16
  1. Did I not break anything, then? everythink is OK? my PC was rebooted and no problem was raised, but now the login console differs. I will look into the next steps to stay updated. If the information I am reading is accurate, the branch jump is risky . Some hint about How to update my system? (i came from archlinux , and the branch concept is something new for me) Thanks for the response.
  2. Hello people, I'm not a debian user so i'm not understand all concepts about apt and how the diferentes branch and dependencies are managed. Can you help me with the following case? (i tried to look for in forums without success, the information that I've found is referenced to another branch noble instead my branch 'focal' but i think it could be similar) i executed the following: sudo apt autoremove what it removed the following package: armbian-bsp-cli-rk322x-box thinking that it could be relevant for my SoC device i tried to install it again: sudo apt install armbian-bsp-cli-rk322x-box > The following packages have unmet dependencies: armbian-bsp-cli-rk322x-box-current : Depends: base-files (>= 25.2.3) but 11ubuntu5.8 is going to be installed E: Unable to correct problems, you have held broken packages. have i broken my system? how could i resolve it ? lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 20.04.6 LTS Release: 20.04 Codename: focal if you can help me it would be appreciated. thanks in advance.
  3. Hello people, I'm not a debian user so i'm not understand all concepts about apt and how the diferentes branch and dependencies are managed. Can you help me with the following case? (i tried to look for in forums without success, the information that I've found is referenced to another branch noble instead my branch 'focal' but i think it could be similar) i executed the following: sudo apt autoremove what it removed the following package: armbian-bsp-cli-rk322x-box thinking that it could be relevant for my SoC device i tried to install it again: sudo apt install armbian-bsp-cli-rk322x-box > The following packages have unmet dependencies: armbian-bsp-cli-rk322x-box-current : Depends: base-files (>= 25.2.3) but 11ubuntu5.8 is going to be installed E: Unable to correct problems, you have held broken packages. have i broken my system? how could i resolve it ? lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 20.04.6 LTS Release: 20.04 Codename: focal if you can help me it would be appreciated. thanks in advance.
