Hi
I don't have found another thread for my question, so i will try it here.
I have a stationpc p2 which runs armbian v22.02.0-trunk, kernel ist 4.19.219-station-p2. The System boots from eMMC and everything i need (LAN, WiFi) works so far (no GUI needed). Now i installed an SSD, added a partition and startet nand-stata-install and select "Boot from SPI - system on SATA, USB or NVMe". The tool copied the rootfilesystem into the created partition and tried to install the bootloader into the SPI, but that won't work. I get an errormessage "SPI u-boot image not found!"
I do not exactly understand what i'm doing here and this "/dev/mtd..." SPI-ROM? devices confused me. My linux knowledge is mostly from x86 Systems which boot process is very diffrent. After checking the involved scripts, i expect that the rkspi_loader.img is not found.
This rises following questions:
It's suposed that the rkspi_loader.img is missing?
Is it even possible to boot from SSD?
if yes, how?
or is it needed to boot from another drive? (eMMC, SD-Card)
Best Regards
Oliver
