LightJolteon
  1. Hello, I've been trying to use the automated script on an Odriod HC4 running Ubuntu Jammy 5.17.5, but it always fails at some point after running APT with some illegal instruction errors. I pasted the output of the script below. I've never really asked for help on one of these forums before and I'm kind of a noob, so if I'm doing something wrong or if more information is needed then let me know. ┌───────────────────────────────────────────────────┐ │ ⣎⣱ ⡀⣀ ⣀⣀ ⣇⡀ ⠄ ⢀⣀ ⣀⡀ ⣏⡉ ⣀⡀ ⢀⣀ ⡀⣀ ⡀⢀ ⣀⡀ ⣰⡀ ⢀⡀ ⢀⣸ │ │ ⠇⠸ ⠏ ⠇⠇⠇ ⠧⠜ ⠇ ⠣⠼ ⠇⠸ ⠧⠤ ⠇⠸ ⠣⠤ ⠏ ⣑⡺ ⡧⠜ ⠘⠤ ⠣⠭ ⠣⠼ │ │ ⣏⡱ ⢀⡀ ⢀⡀ ⣰⡀ ⣏⡉ ⠄ ⡇ ⢀⡀ ⢀⣀ ⡀⢀ ⢀⣀ ⣰⡀ ⢀⡀ ⣀⣀ │ │ ⠇⠱ ⠣⠜ ⠣⠜ ⠘⠤ ⠇ ⠇ ⠣ ⠣⠭ ⠭⠕ ⣑⡺ ⠭⠕ ⠘⠤ ⠣⠭ ⠇⠇⠇ │ │ ⢎⡑ ⢀⡀ ⣰⡀ ⡀⢀ ⣀⡀ │ │ ⠢⠜ ⠣⠭ ⠘⠤ ⠣⠼ ⡧⠜ │ └───────────────────────────────────────────────────┘ For detailed usage information, invoke with the '-h' switch get_armbian_image OK apt_install_host OK close_loopmount OK umount_target OK remove_build_dir OK Will write to target /dev/sda (Mass Storage Device 59.5G) check_sdcard_name_and_params OK create_build_dir OK Enter the IP address of the target machine. Enter 'dhcp' for a dynamic IP or 'none' for no remote SSH unlocking support IP address: 192.168.1.5 Enter the netmask of the target machine, or hit ENTER for the default (255.255.255.0): Enter a boot partition label for the target machine, or hit ENTER for the default (ARMBIAN_BOOT): Enter a device name for the encrypted root filesystem, or hit ENTER for the default (rootfs): Choose a simple disk password for the installation process. Once your encrypted system is up and running, you can change the password using the 'cryptsetup' command. Enter password: 123 Unlock the disk from the serial console. WARNING: enabling this will make it impossible to unlock the disk using the keyboard and monitor, though unlocking via SSH will still work. Enable unlocking via serial console? (y/n): n Unlock the disk via SSH over USB (g_ether). Enable this only if your board supports USB gadget mode, i.e. if it has a USB OTG port. WARNING: enabling this will make it impossible to unlock the disk over the Ethernet interface (eth0). Enable unlocking via SSH over USB? (y/n): n The following user options are in effect: + use local 'authorized_keys' file Armbian image: Armbian_22.05.1_Odroidhc4_jammy_edge_5.17.5.img Target device: /dev/sda (Mass Storage Device 59.5G) Root filesystem device name: /dev/mapper/rootfs Target IP address: 192.168.1.5 Target netmask: 255.255.255.0 Boot partition label: ARMBIAN_BOOT Disk password: 123 Serial console unlocking: no SSH over USB unlocking: no Are these settings correct? (Y/n) y get_authorized_keys OK Copying boot loader (8192 sectors, 4M): 4+0 records in 4+0 records out 4194304 bytes (4.2 MB, 4.0 MiB) copied, 0.421957 s, 9.9 MB/s copy_boot_loader OK partition_sd_card OK Copying files to boot partition: 101,080,678 99% 10.77MB/s 0:00:08 (xfr#145, to-chk=0/152) copy_system_boot OK create_bootpart_label OK Copying system to encrypted root partition: 1,186,326,943 99% 16.16MB/s 0:01:09 (xfr#37888, to-chk=0/47428) copy_system_root OK mount_target OK Host Target ---- ------ distro: jammy jammy kernel: vmlinuz-5.17.5-meson64 vmlinuz-5.17.5-meson64 Unable to copy '/etc/apt/apt.conf.d/*proxy' to target (file does not exist) armbian_rootenc_setup.sh:891: _copy_to_target() failed at command 'false' Host script exiting with error (1) armbian_rootenc_setup.sh:905: copy_etc_files() failed at command 'false' Host script exiting with error (1) copy_etc_files OK copy_etc_files_distro_specific OK edit_initramfs_conf OK edit_initramfs_modules OK copy_authorized_keys OK create_etc_crypttab OK create_fstab OK edit_dropbear_cfg OK netman_manage_usb0 OK ifupdown_config_usb0 OK create_cryptroot_unlock_sh OK edit_armbianEnv OK Reading package lists... Done Building dependency tree... Done Reading state information... Done The following packages will be REMOVED: bash-completion* 0 upgraded, 0 newly installed, 1 to remove and 31 not upgraded. After this operation, 1,499 kB disk space will be freed. (Reading database ... 41456 files and directories currently installed.) Removing bash-completion (1:2.11-5ubuntu1) ... Processing triggers for man-db (2.10.2-1) ... (Reading database ... 40694 files and directories currently installed.) Purging configuration files for bash-completion (1:2.11-5ubuntu1) ... Generating 256 bit ecdsa key, this may take a while... 256 SHA256:kcNv1yOFs+xQjuvdzjF23A6r/Qy4BK6dKaLf7A1bK3c /etc/dropbear/initramfs/dropbear_ecdsa_host_key (ECDSA) +---[ECDSA 256]---+ | | | . . . | | = + . | | + = = | | S * * o | | o * o o.| | . + + * +| | .ooO.*E* X | | .o.o*+B.+o*.+| +----[SHA256]-----+ Generating Dropbear ED25519 host key. Please wait. Generating 256 bit ed25519 key, this may take a while... 256 SHA256:M2QMUYkhLLtOLyRZRDUfguhidpEAEp5o6i9WNmBoc1w /etc/dropbear/initramfs/dropbear_ed25519_host_key (ED25519) +--[ED25519 256]--+ |==o+* ==.. | |= =o.E.+. | |+=.oo . + | |=Oo+ o | |Bo=. S | |+ ++ o | | *o.. | | o+ . | |. .o | +----[SHA256]-----+ update-initramfs: deferring update (trigger activated) Dropbear has been added to the initramfs. Don't forget to check your "ip=" kernel bootparameter to match your desired initramfs ip configuration. rmdir: failed to remove '/etc/dropbear-initramfs': Directory not empty ERROR: Couldn't remove directory /etc/dropbear-initramfs Processing triggers for libc-bin (2.35-0ubuntu3) ... Illegal instruction Illegal instruction dpkg: error processing package libc-bin (--configure): installed libc-bin package post-installation script subprocess returned error exit status 132 Processing triggers for man-db (2.10.2-1) ... Processing triggers for initramfs-tools (0.140ubuntu13) ... update-initramfs: Generating /boot/initrd.img-5.17.5-meson64 Illegal instruction Illegal instruction update-initramfs: Converting to u-boot format Errors were encountered while processing: libc-bin E: Sub-process /usr/bin/dpkg returned an error code (1) armbian_rootenc_setup.sh:1149: apt_install_target() failed at command 'apt --yes install $pkgs' Target script exiting with error (100) armbian_rootenc_setup.sh:1213: configure_target() failed at command 'chroot $TARGET_ROOT "./$PROGNAME" $ORIG_OPTS 'in_target'' Host script exiting with error (100) Cleaning up, please wait... close_loopmount OK umount_target OK update_config_vars_file OK remove_build_dir OK
