I'm trying to load Armbian onto a NanoPi R4S, but an running into problems where it won't start with certain versions, and running apt update breaks it on other versions.
I've hooked up the serial interface so I can see what's going on during boot, so there are pastebin links to the logs.
Fresh Image (Jammy/Focal):
Trying to use Jammy or Focal I cannot the the board to boot at all with a completely fresh image. The error message complains that the UUID for the main partition does not exist
Log: https://pastebin.com/gQeyhVf5
Fresh image (Bullseye/Buster), post account creation:
Bullseye and Buster will initially boot, but sometimes will not boot properly if doing a soft-reboot (ie. sudo reboot now), requiring a hard power-cycle to boot (which is a bit annoying since the board won't be in the easiest place to get to). At this stage I haven't done anything except the initial prompt to change the root password
It has the same error message that UUID does not exist
Log: https://pastebin.com/cnNbZVFT
Post apt update/upgrade (Bullseye/Buster):
With both Bullseye and Buster, I run apt update and apt upgrade since it's generally a good idea to keep packages up-to-date for security. I didn't change any other files or do anything else except run the update
However in both, after running apt upgrade it is no longer able to boot no mater how many times I power cycle it. Also complains UUID does not exist
Log: https://pastebin.com/pqyxBrvS
After apt update was complete, but before power cycling/rebooting it I did check the UUIDs of the partitions using blkid and also checked /boot/armbianEnv.txt to check if either had changed. But the UUID's still matched what they were previously so it doesn't seem that anything got changed or corrupted
In all the cases where it won't boot it seems to be complaining that the UUID for the rootfs doesn't exist. And I'm not sure how to fix it
